New Push Rods?
Old Sep 22, 2004 | 08:07 PM
Grace91's Avatar
Grace91
Default New Push Rods?
Comp Cams says new push rods must be installed with there magnum rockers. Is this true or just ?
My L98 has just under 50K on the clock and the internals look fairly clean. What do you guys normally do on a new rocker install? Do you typically install new push rods?
Old Sep 22, 2004 | 08:10 PM
comp's Avatar
comp
it is best
Old Sep 23, 2004 | 08:54 AM
conv90's Avatar
conv90
If you are instaling Pro Magnum NON self aligning ones you NEED new pushrods.
Non self Align uses guideplates and you NEED hardened pushrods. (the stock ones are not.)
-Beppe-
To New Push Rods?
