I have a 90 vert auto with the G92 option and I checked (turning the rear wheel one turn and seeing how many turns does the shaft) and it is a 2.73.
The best way to check is to turn the rear wheel 10 times and see if the shaft turns 26 times, 27 times or 31 times (the first is 2.59 , the second scenario is 2.73, and the third is 3.07.
-Beppe-
3.07 with Performance Ratio. Or so it's SUPPOSED to be!
-E
G92 DOES mean, "Performance Ratio". But just as the standard ratio varies from year to year, transmission, and sometimes the body, so does the "performance ratio". Like vader86 said, get the OTHER "G" number. THAT will be the actual ratio designator. In EPiC Vette's example above, the G44 IS a 3.07:1 ratio. The G92 means nothing, really. Unless it pumps your ego knowing it's the "performance ratio". EPiC Vette doesn't sound overly thrilled. A 3.07 is a 3.07, regardless of what you label it.
Yes it does, it means it doesn't have the base axle in the car. SO what I am trying to figure out is what ratio is in a vert auto with g92 2.73 or 3.07. Seems I read somewhere that they didn't put the 3.07 in the verts. Guess I will have to go spin the driveshaft.
From the factory they wrote on the bottom of the differential the part number and ratio in black magic marker. You may have to clean any grease and grime off. Use something like Windex so that you dont take off the black marker.
BIG DEAL! So you know you don't have the base ratio in YOUR car. If it is so meaningful, why are you asking for your ratio??? The ratio designating code should be very close to where you found that all important "G92".
I don't know about your year but for my 87
The base for the convertible is 2.59 and the perf one is 2.73.
For the coupes the base is 2.73 and the perf is 3.07.
I got this information out of my manual.
for the 87 vert if the perf option is g92 the ratio is 2.73.
This is for an auto
Check your manual.
From: Why are there squished peanut butter cups in my underware?
Originally Posted by LT4BUD
G92=3.07 Cost $22.00 confirmed on several sites......Standard ratio is really tough to find on the net...I still put my $ on 2.59 & 2.73
survey says...XX
Before you lose the prize $$$ to the Miller family, here's the rear axle info for the 1990 model year;
2.59 RPO-GM1 base auto coupe & conv
2.73 RPO-GU2 optional auto conv
3.07 RPO-G44 optional auto coupe
RPO-G92 optional "performance axle" for automatics
3.33 RPO-GT7 6-sp manual for L-98 engines coupe & conv
3.45 RPO-GM3 6-sp manual for LT-5 engines ZR-1 coupes
Originally Posted by wildman378
my convertible with g92 has the g44 3.07's it's a 95 though.
That's correct.
G92 is the code for an extra cost option. G92 must have an optional ratio.
For a `90 vert it is GU2 2.73, different than coupes
For a `95 vert it is G44 3.07, same as coupes
Standard for both years is GM1 2.59
That's correct.
Cool, I just wonder why they only put the 2.73 as the performance ratio in 1990. Why not just put the 3.07's in then too yanno, just found it weird the vert got a diff ratio bc it's a vert.
