Not understanding the Mini-Ram! Help me out
so bottom line is .....whats up with this Mini-Ram thing....can adding 75 extra horses be this easy? and whats the difference between this and the Superram?
thanks guys....oh yeh....here's a copy paste from TPIS's site in which I read bout the Mini-Ram.
Mini-Ram Intake Manifold
This fabulous one-piece casting is ideal for the serious car nut. If used as a replacement over a stock Tuned Port intake, on a mild 350ci motor, you will see a 75-95+ HP gain. If you build the motor on the mild side, i.e. small cam and some porting, stroker motor, 100-125+ HP,over the stock or modified TPI intake is very possible. If you go on the wild side you will be able to exceed any single four barrel power numbers, all with greater driveability and economy.
Installs on existing TPI vehicles with just our Fuel Rail Kit and Level VI Prom. Use the Mini-Ram to replace and out-perform any carbureted system.
We have been driving this manifold for over ten years. It has wonderful throttle response, delivers more torque from 2000 to 2700 RPM than a stock or modified TPI, and gives a great rush of power from 3500 RPM to 6500 RPM.
The reason the TPI intake is so restrictive is due to its intake runner length, which is 17 inches long! Your typical carburator intake is about 5-6 inches long, and our Mini-Ram intake is 3 inches long. The shorter the runner the higher the peak RPM, the higher the peak RPM, the higher the HP number. This is why it makes so much more power.
On a built 350 with a bigger: base manifold, runners, ported plenum, 52mm T/B, and a ZZ-9 cam, peak HP is 380 at 4750 RPM,and peak torque will be 460lbs/ft, Put a Mini-Ram on the same motor, and peak HP will be 450 at 6000 RPM, with 430lbs/ft of torque. Sure you lose some torque, but you will still have a hard time hooking up, so the torque loss is not an issue. Over a stock TPI you would see easily over 100 more HP. If we do the same combo with a 383 the modified TPI would only be at 400HP at 4500 RPM, and 515lbs/ft of torque, basically a tow truck motor, all torque, and no RPM or top end. Put a Mini-Ram on and you will see 480HP at 5800 RPM, with 490 lbs/ft of toque, and a lot flatter toque curve, over a TPI long runner intake. And once again you will still have trouble hooking up.
This same runner concept is why the LT1 motors made 60 more HP over the TPI motors out of the box. If you look at stock TPI aluminum head flow numbers, and compare them to stock LT1 aluminum head flow numbers, you will see little difference, also the cam specs are very similar, and the throttle bodies, and cubic inches are the same. So why does the LT1 make more power? Simple, intake runner length, is the main difference, shorter runner more RPM, and RPM is HP. If GM put a 17 inch long intake runner on the LT1 motor, the numbers would be the same as the TPI motors.
Now looking at that graph you can see that at 6000 or 6500 RPM there is going to be nearly nothing for HP being made anymore. The miniram using their wording would instead give you +75-90 at that same 6500. This is of course if you match it properly with the other components needed. The trade-off is that you might see a drop in the lower end. Especially if you didn't swap the cam etc.
but...ummmmmmm is your chart right?
Looks to me that your top horsepower is at 210? is that it? oh wait....is that actually RWHP? or is that crank......
They present dyno tables that show peak power was up about 73chp upon replacing the stock TPI setup with a mini-ram on an '85 Vette. Gees if I thought I could realy gain that much CHP on my '88 L98 for ~$800 I'd cut the check to them tonight.
According to their dyno data on a 383 the mini-ram not only alows your engine to breath much better up top but also costs little or no low end, down to 2,500rpm anyway.
was the reason they ran out of HP.But because of long runners they
have a lot of torque.Who would be the person that knew about this?
I did the TPI to mini ram swap and still feel that it was the best decision for my long term plans. Did my cam and heads at the same time. My observations for my 350 are:
1. Expensive
2. No EGR
3. Much easier to install and work on than the SR and TPI setups
4. Love the shift in power band...I like being able to rev the engine
5. Need more gear on the 350
6. Runs cooler than the TPI and SR setups because of no EGR...helps compensate for reduced mid range power for runner length tuning effect.
7. One of the better manifolds, if you are planning to add cubic inches.
8. Must do a custom chip to take advantage of the shift in power band.
When driving on the interstate at 60-70mph, when I nail it, it is really pretty unbeliveable in the way the car takes off.
I will likely put 3.73 rear gear in my car this winter and I think it will complete the package nicely. TPIS will tell you that you need at least 3.73's or there abouts to take advantage of the MR.
You also need alot of rear gear for a good MR setup, and that means youll have to upgrade the rear end in an automatic.
In an automatic, youll need a higher stall TC as well.
I also recommend that anyone doing a miniram consider some bottom end upgrades due to the longer time spent in higher RPM areas compared to stock.
