Currently with my 3.07 D36 rear end, I have a 17 Tooth Drive and 42 tooth driven gear. When I change to the D44, would the Vehicle Speed Sensor change too? Or would I just change to the 15 tooth drive gear and be happy? TIA
You will have to change the gears for sure. There is a formula in one of my tpis books that tell how. I Know that 3:73 gears need the gray drive gear with the 45 tooth driven gear. I do not know the correct gears for your application off hand. Maybe someone else will chime in. I will try to locate my book for the conversions.
Yes! The speed sensor only changes with a driven gear change, and only sometimes. Neither the transmission nor the speedometer, know or care WHAT rear end is in the car. Only the "ration" matters. That is the correct set up for a 3.45 ratio.
I didn't try to calculate it. I simply looked it up, confirmed your selection, and advised you on the VSS. *I* can't answer for GM. Maybe you ought to ask THEM.
