Need 6sp upgrade info...
Old Sep 24, 2004 | 09:04 PM
BlkMagik's Avatar
BlkMagik
Default Need 6sp upgrade info...
I would like to know where I can buy (and how much) an all-in-one 6-speed kit to replace my 86' 4+3 trans? I thought that I saw a post about a conversion kit that was around $2K but I don't remember.
Ok, the 4-speed trans I pulled yesterday had no oil in it and will need around 600 bucks in just parts to repair. I'm not sure what the labor will be but I figure ball park around 500 bucks. My supposedly new clutch (with less than 6Kmiles) is totally "F"ed. My thought is: why not get a 6-speed setup now since the tranny and clutch are toast.
Any comments/advise would be appreciated!
Old Sep 24, 2004 | 09:45 PM
LD85's Avatar
LD85
Tranny alone is $1800 + shipping from
www.gmpartsdirect.com
Part # 12455189
http://home.cfl.rr.com/todd80z28/pro...56_Install.htm
Old Sep 24, 2004 | 09:52 PM
LD85's Avatar
LD85
http://hometown.aol.com/corvettez51r...age/index.html
BTW, figure on $2500- $3k
Tranny w/shifter, BU switch & Speed Sensor NEW $1800 + shipping
ZF Bellhousing $125 + shipping
ZF Pull type Clutch, Disc & PP $ 275
Clutch Slave $90
Clutch Master $100 though not required if you use your master
Hydraulic hose $80
Flyweel $300 if you do a single mass conversion
Rear Yoke for drive shaft $50 from Salvage yard
C Beam, use your 86's
Longer ZR 1 ball stud $25.00
Someone correct me please if I have left any thing out
Old Sep 24, 2004 | 10:42 PM
BlkMagik's Avatar
BlkMagik
Hmmmmm. Sounds like lots of $$. I wonder if the 1-1.5K$ to fix the 4-speed is a better idea. But, then if the O/D unit needs repair soon I would have spent about the same on the 6-speed which would probably outlast the rest of the rig I would think.
Old Sep 24, 2004 | 11:19 PM
LD85's Avatar
LD85
The 4+3 "I AM TOLD" can handle 280RWHP, if you have less than that or @ 350 FWHP you should be OK.
Actually, I really liked and miss the 4+3, its a really nice tranny, but could not handle 403RWTQ.
I know they can be fixed for $1100
Old Sep 24, 2004 | 11:41 PM
93ZF6's Avatar
93ZF6
There is another option, a kit to put in a 5 speed I think it is the tremec. This kit is done by a company called Keiser engineering, they advertise in the Vette Mags and were at Carlisle with kits from C2-C4.
Old Sep 25, 2004 | 03:07 AM
LD85's Avatar
LD85
This can be yours for a paltry $3500
Old Sep 25, 2004 | 03:09 AM
BlkMagik's Avatar
BlkMagik
cool looking kit but it's 3grand...
To Need 6sp upgrade info...
