Coil Overs Vs New Leaf Spring
Old Sep 24, 2004 | 11:03 PM
Hammer's Avatar
Hammer
Default Coil Overs Vs New Leaf Spring
This is probably an ignorant question....
The rear leaf spring broke, If I get coilovers can I take the leaf springs out?
How much are the Hal adjustable coil overs?
Jim
Old Sep 24, 2004 | 11:20 PM
vader86's Avatar
vader86
Well it would be dumb to have leaf springs AND coilovers.
I dont even know if you could use both at the same time.
Certainly, you can remove the transverse leaf if you go to coilovers.
Old Sep 24, 2004 | 11:22 PM
Trog's Avatar
Trog
You can buy my rear leaf for cheap if you want. I went to coil overs early this year.
Old Sep 24, 2004 | 11:24 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I had a parts list running round at home...
Old Sep 24, 2004 | 11:41 PM
Hammer's Avatar
Hammer
Trog,
How much do you want shipped to zip code 11769?
Jim
Old Sep 25, 2004 | 12:01 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Jim
My mother always said, "We're all ignorant, just on different subjects." The coil conversions are rather pricey. It's something I may do someday, but there's a zillion other things I want to do first. You've got a nice offer for a used spring. That'll get you back in business fast. The rear is very easy to change.
Old Sep 25, 2004 | 12:45 AM
JA94vette's Avatar
JA94vette
What all is involved as far as parts in a coilover conversion. Does it simply bolt up or does it require extensive modification to suspension parts. Also, does anyone have a rough estimate? And I saw that someone thought that they might have a parts list. If you could find it, I'd greatly appreciate it.
Old Sep 25, 2004 | 12:55 AM
Coupe89's Avatar
Coupe89
Rear: Remove the spring, shock and turn around the lower control arm bolt on both sides. Bolt in the coil-over
Front: Remove the spring and shock. On the 89-96 open the shock tower about 1/8" on both sides. Move the sway bar forward about ~1/2" Bolt in the coil-over
Cost ~$700
Old Sep 25, 2004 | 01:01 AM
Corvette Kid
Cost ~$700
That's not bad. The numbers I'd seen on here before were always well over a K.
Old Sep 25, 2004 | 01:14 AM
JA94vette's Avatar
JA94vette
Wow...that doesn't seem bad at all. Do you know who sells the kit?
Old Sep 25, 2004 | 01:17 AM
vader86's Avatar
vader86
Doug Rippie sells a set, I dont know who all else.
Old Sep 25, 2004 | 02:08 AM
Coupe89's Avatar
Coupe89
I have to look for the part numbers for the QA1 system.
I have the DRM system right now....
Old Sep 25, 2004 | 02:10 AM
Trog's Avatar
Trog
Depending on year the DRM kit requires moving the rear upper shock mount about 1/2" forward. It was a bit of a pain but I have air tools & a mig welder so when I was done it looked almost like stock... :-)
Old Sep 25, 2004 | 02:35 AM
Coupe89's Avatar
Coupe89
QA1
TC3024P - Rear Coil-overs ($139.95@)
TC3014P - Front Coil-overs ($139.95@)
HAL-SS110SDM - Stud Ends* ($32.99@)
HAL-UPR350 - Upper T Bar* ($22.99@)
Springs ($36.88@)
*Might be inclued - Just looked at Summit Racing...
Old Sep 25, 2004 | 02:36 AM
Coupe89's Avatar
Coupe89
My DRM units come with upper shock mount...
To Coil Overs Vs New Leaf Spring
