HP rating
Old Sep 25, 2004 | 12:03 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
Default HP rating
Im building a new engine for my 86,bored it 030 over,with a .449 intake .456 exhaust gross lift cam (comp cam part # 12-256-4)and the recomended springs,match ported heads and intake,5 angle valve job,with 1.6 roller rockers.No cats and flow master mufflers.just wondering if anybody would know what kind of HP I can expect
Old Sep 25, 2004 | 12:14 PM
CFI-EFI's Avatar
CFI-EFI
1282 HP, but only on a cloudy day. ??????
RACE ON!!!
Old Sep 25, 2004 | 12:24 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
Sweet I sould have bought better tires
Old Sep 25, 2004 | 12:42 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
I wouldn't expect miracles due to to the dinky cam.
My guess would be 260-270 FWHP
Old Sep 25, 2004 | 01:20 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
I didn't want to go big .It's going ot be driven daily and gas is outragous.Just wanted to give it a little more dependable power.And it has to pass emitions.
Old Sep 25, 2004 | 03:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well, you might gain about 15chp from the cam, maybe 10chp from the heads work (assuming they are not touching the bowls), ??? from the bore, and maybe 10chp from the exhaust work (assuming you still have the stock pre-cats and the stock cat).
This also assumes you have done no work on the intake, nothing with the T-stat nor with fuel delivery nor the chip.
Old Sep 25, 2004 | 09:31 PM
Bruce's Avatar
Bruce
Get rid of that iron head and slap on a set aluminum head with 2.02/1.60 you can get this from Summit for a hair over $1000. Don't use that baby *** cam. You can use LPE219 cam without the use of the super ram and it still make good hp and pass emission. Or LPE 211/219 cam.
Bruce
Old Sep 25, 2004 | 10:22 PM
comp's Avatar
comp
what about a set of long tube's
Old Sep 27, 2004 | 07:58 PM
AZ Z51's Avatar
AZ Z51
St. Jude Donor '05
Bruce
I also have two LT1 cores that I plan on building a 383 stroker out of.Then I,ll find a beat up C4 and build a beast.Lite and fast no a/c no b/s just full race.
To HP rating
