ProCharger upgrade
Old Sep 25, 2004 | 02:22 PM
Bruce's Avatar
Bruce
Default ProCharger upgrade
Any one know what ATI charge to upgrade their old head unit to a bigger one? Example I got a D1SC if I would do a upgrade to a F1R blower what would they charge? I know the F1 will bolt right up with the D1SC bracket, will the F1R required new bracket oe still can reuse the D1SC bracket? If anyone please chime in.
Bruce
Old Sep 27, 2004 | 01:12 PM
vvv90's Avatar
vvv90
Bruce
I don't think you can go from a D1-sc to an F1. The case has to be the same. Or at least, that's what they told me.
For example, you can go from a P1-SC to a D1-SC, but you CANNOT go from a P-600b to a P1-SC....even though the size of the blower looks to be the same:
http://www.procharger.com/models.shtml
Give them a call.
FYI, A P1 to D1-SC upgrade they quoted for me was ~$1100!!!
Old Sep 27, 2004 | 03:07 PM
Bruce's Avatar
Bruce
You are right. I cannot go from a D series to F series. Maybe some day I will find use one on EBAy.
Bruce
Old Sep 27, 2004 | 07:21 PM
Brand-X's Avatar
Brand-X
F1 is a direct bolt in from what I've hear...the case has the same bolt holes but the case is slightly wider.
Old Sep 28, 2004 | 12:01 AM
Bruce's Avatar
Bruce
Chris
I emailed Lonnie Pavtis, he says the F1R is still using the same bracket as the D series blower. It is a little bigger and the volute is .750 larger. If I am going to get the F1R down the road, I should not have any problem with it. I have cut up some of my radiator shroud already for more room where the plenum hat is. That leave me about 2" + more space. So if the F1R is thicker and I won't have a problem with hooking up the blower air intake. But that something I might looking into down the road of install a F1R.
Bruce
To ProCharger upgrade
