How much is .7 mm??
Old Sep 25, 2004 | 05:42 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default How much is .7 mm??
I found a set of wheels pretty cheap to use as a back up...the offset is 5x120mm. The Vette offset is 5x120.7mm. How can I make these fit?
Old Sep 25, 2004 | 05:49 PM
hngacurv's Avatar
hngacurv
25.4 mm in an inch
.7/25.4 = .02755 inch
Old Sep 25, 2004 | 05:50 PM
Southern Comfort's Avatar
Southern Comfort
Old Sep 25, 2004 | 05:54 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Yea but will they go on the car?
Old Sep 25, 2004 | 06:13 PM
vader86's Avatar
vader86
That difference is so small you wouldnt even notice.
Theyll fit with no problems as long as its a GM lug pattern.
Old Sep 25, 2004 | 06:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's between 1/32" & 1/64"....I doubt that your corroded stock wheels have that close a tolerance now.
Go for it!
Old Sep 25, 2004 | 06:20 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Corroded! Corroded?!? Hell I hope not Callaway wants 1900/each for them
Cool. I was just reading up...basically any 5 bolt pattern with 5x120mm pattern will fit the car.
Sweet!
Old Sep 25, 2004 | 07:44 PM
comp's Avatar
comp
Go for it!
Old Sep 25, 2004 | 07:50 PM
LD85's Avatar
LD85
1mm = .039375"
Old Sep 25, 2004 | 08:13 PM
CFI-EFI's Avatar
CFI-EFI
How the heck does OFFSET get expressed as 5X120mm?????? As your diagram illustrates, that sounds like a spec for a BOLT pattern.
Offset is the distance from the back part of the wheel that sits against the hub or rotor, to the centerline of the rim. There are both positive and negative offsets, but it is a single dimension, like 4.5" or 55mm.
IF the bolt pattern will fit the hub, there IS offset to consider. GOOD luck, and...
RACE ON!!!
To How much is .7 mm??
