How to pull ODB1 codes
Old Sep 26, 2004 | 02:30 PM
Blues77's Avatar
Blues77
Default How to pull ODB1 codes
I searched archives and google. Its amazing how simple information is so hard to find lately. Just broken links to other info sites.... end rant. What pins do I jump, and what do the codes = to. ODB 1 for 94
Old Sep 26, 2004 | 02:50 PM
CFI-EFI's Avatar
CFI-EFI
"A" to "B". The first code of "12" tells you the ECM is comunicating with the ALDL. All the others are in your service manual, along with the trouble shooting charts for each code. Give us your code(s), and maybe we can help. Just remember a code from a given sensor doesn't necessarily mean the SENSOR is bad. That's where the trouble shooting comes it.
RACE ON!!!
Old Sep 26, 2004 | 03:04 PM
bogus's Avatar
bogus
These codes flash... <blink> short pause <blink><blink> = 12, it will be repeated 3 times, then the code, for example, 52 would be <blink><blink><blink><blink><blink> short pause <blink> <blink> long pause, repeat code.
That will repeat 5 times.
then code 12 will appear, and then the next code. If there is only 1 stored code, then it will appear next.
As CFI-EFI said, if you have a code, it does not mean the sensor is the problem. It could be any number of other issues. For example, you get an EGR code. That codes presentation is very important. If it comes on IMMEDIATELY after starting and stays on, the problem is with the EGR control, if it takes 20~30 minutes of driving, then it's the valve itself. You see, if it fires immediately, that means the control failed the self test.
subtle, I know...
Old Sep 26, 2004 | 03:17 PM
CFI-EFI's Avatar
CFI-EFI
Is it 5 times in later cars? Mine flashes the "12" three times. Then the first fault code, 3 times. After the first fault code has flashed 3 times, it moves on to the second fault code, if any. Et cetera. The "12" doesn't reappear until all the fault codes have been displayed, signaling "the end".
RACE ON!!!
Old Sep 26, 2004 | 03:38 PM
Blues77's Avatar
Blues77
duh its in my haynes, thanks guys..
me
edit: my LTPWS is what flashes. i only get the 12 once in the beg. then each code three times, then the 12 once at the end.
Old Sep 26, 2004 | 05:04 PM
bogus's Avatar
bogus
RACE ON!!!
duh, you are right. I thought I fixed that.
Old Sep 26, 2004 | 05:05 PM
bogus's Avatar
bogus
me
oh. that's annoying at best.
Before you go any farther, get the Helms Manual... You won't be able to fix jack with the Haynes. These cars are SO complex...
Old Sep 26, 2004 | 07:14 PM
Red Dwarf's Avatar
Red Dwarf
If you have a 16 pin DLC?.....jumper pins 12 & 4. It shud display on the speedo. Go to c4vettes.com for more info. Select Fact Sheets & then Trouble code recovery.
Old Sep 26, 2004 | 07:48 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Just a thought!
EZ Link costs about $200 and besides pulling codes allows you to read real time data too!
I was having problems last fall and winter on my 88! Was running awfull but not throwing any codes
EZ link let me read the values to and from ECM and I isolated the problems.
Repairs/replacements were inexpensive and I easily recovered the cost of the EZ link with the money I saved from not just buying expensive parts and hoping they solved the problem!
seeya
Jack
Old Sep 26, 2004 | 08:15 PM
bogus's Avatar
bogus
I tried to get to www.c4vettes.com today, the link didn't work. I hope they are ok!
Old Sep 27, 2004 | 10:58 AM
Red Dwarf's Avatar
Red Dwarf
It comes & goes, keep after it.
To How to pull ODB1 codes
