1984 Corvette - If I take the halfshafts out to change u joints is there any marking needed? I mean do I need to mark left or right, or inside/outside on each shaft or are they completely universal and it doesn't matter?
Nope, put em' in however you'd like to. If you use u-joints with zerk fittings try to install them opposite each other in the halfshaft.
If you haven't bought the u-joints yet, try to get the spicer parts, Napa sells them, the zerks are located on the end caps and not in the valleys... Better design by far..........
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Racers at the track (SCCA) always mark them so they go back exacly the same way they were on the car.
Why?
There's always a certain amount of twist in the shafts from running them hard, not that you can see it. This weakens them somewhat, so if they're flipped they'll fail.
Why?
