1996 Auto shifter modification
Old Sep 26, 2004 | 05:08 PM
badddrx7's Avatar
badddrx7
Default 1996 Auto shifter modification
Has anyone removed the Stock Auto shifter in a 96 and removed the push button linkage from it so you can shift without pushing that silly button down ? Also this would make it easier for a new shift **** install ? Can it be done ?
Thanks, Tom
Old Sep 26, 2004 | 05:24 PM
scorp508's Avatar
scorp508
I just have to ask.... why would you want to do that? It'd suck to accidently slip it into R when you're doing 100.
Old Sep 26, 2004 | 05:37 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Really.... you can upshift w/o pushing it if you want, so what's the point? Yes, it's do-able though, to answer your question.
Old Sep 26, 2004 | 05:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You should be able to do the job by simply removing the return spring at the base of the shifter mechanism.
However, I must agree with Brian as to the danger involved with such a setup.
Old Sep 26, 2004 | 06:34 PM
silver & red CE's Avatar
silver & red CE
Instead of the shifter, why not put in a shift kit? That and a looser TC will make your A4 perk right up!
Eric
Old Sep 26, 2004 | 06:58 PM
CFI-EFI's Avatar
CFI-EFI
Just in case you care, it won't pass NHRA tech, modified like that.
RACE ON!!!
Old Sep 26, 2004 | 10:07 PM
badddrx7's Avatar
badddrx7
Thanks for the replys. What shift kit do C4 auto owner normally install in their cars ?
Tom
Old Sep 26, 2004 | 10:17 PM
silver & red CE
TransGo
Old Sep 26, 2004 | 11:01 PM
Corvette Kid
Tom
Or, with the electronic trans, which you have, you can accomplish the same thing by boosting shift pressure via the PCM. Now this can be done if you're having reprogramming done, or if you're not, get a Shift Plus module from B&M. It splices into two wires in your PCM harness and has two settings, firm and REALLY firm or you can turn it off and still have stock shifting. About $30 when I bought mine.
Old Sep 28, 2004 | 08:59 AM
silver & red CE
Electronic pressure boost isn't going to move more fluid. It does stress the seals more. The Trans-Go moves more fluid (increasing trans life)and speeds up down shifts too. If you haven't driven a 4L60e with a looser TC and a trans-go, you're missing out.
To 1996 Auto shifter modification
