Paging Nathan
Old Sep 26, 2004 | 08:12 PM
1996man's Avatar
1996man
Default Paging Nathan
and anybody else who knows about cams and such for the LTXs.
how well do you think it would work to take a LT4 and put this cam in
http://forums.corvetteforum.com/showthread.php?t=901626
with the 1.8 rockers that nathan had? with the obviously appropriate springs and such? what are you alls thoughts on that?
Old Sep 26, 2004 | 08:32 PM
redcorvettedave's Avatar
redcorvettedave
I'v followed Nathan's adventures with Roller Rockers and i have concluded that 1.7s is it with the RRs on LTX's....after reading Nathan's post the stock Lt1 cam with 1.7s rr gives just as much or more lift as a stock LT4 cam.....The 1.8s weight was major factor and valve train geometry resulted in Nathan loosing HP . P.s. I bought a set of 1.7s trying to save to have them install on my stock LT1
Old Sep 26, 2004 | 09:35 PM
silver & red CE's Avatar
silver & red CE
That thread doesn't make sense to me. IMHO, the formula for real gains isn't wrapped up in a special cam, it takes a time tested program. I have my doubts about 354 rwhp without long tubes....
Eric
Old Sep 27, 2004 | 11:32 AM
1996man's Avatar
1996man
dave i see what you are saying but i think nathan also said he would probably see the benefit of having the heavier rockers with a bigger cam. i think i remember him saying the hotcam wasnt big enough to maximize the potential of the 1.8 rockers
Old Sep 27, 2004 | 12:47 PM
FD2BLK's Avatar
FD2BLK
If you are going to change the cam why not take care of te added lift with the cam instead of going to a radical valve train. You can get the same lift using 1.6 rcokers and your valve train will be much more reasonable.
Old Sep 27, 2004 | 12:50 PM
1996man's Avatar
1996man
so i could very easily get just as much power with that cam and 1.7 rockers? i guess im not up to speed on the science of rockers. pardon my lack of knowledge
Old Sep 27, 2004 | 12:57 PM
Zix's Avatar
Zix
That cam right now has 570/575 lift with 1.6 RRs. If you went with 1.7s that would change to 605/610 which would require some serious valve springs...going to 1.8's would make it even worse. Most heads after they've been worked over still only support .600 lift if they've been setup for a hydrolic cam. Going much above that is pretty much reserved for solid rollers.
Old Sep 27, 2004 | 01:15 PM
1996man's Avatar
1996man
oh. so what are you alls opinions on this cam? how could i get the most power out of it? 1.7 rockers and aftermarket springs?
i would really like to get 400rwhp without porting my heads. granted i know i will add long tubes and waterpump and other stuff to add HP but i know the main gain will be in the cam and valvetrain. i obviously have the LT4 to start with so i think its a good starting platform. will upgrading injectors help? i think i will up the TB size just a bit as well
Old Sep 27, 2004 | 01:55 PM
FD2BLK's Avatar
FD2BLK
I am a little confused, do you already have the cam installed? If not why not just pick a cam that has what ever lift you are looking for before changing to 1.7 or 1.8 R/Rs? I dont think you are going to see 400rwhp without porting the heads or adding dicplacment. I believe Nathans heads are ported by TEA. My new set up should be in the 400 club but it is a 383 with AFR comp ported heads.
Old Sep 27, 2004 | 02:34 PM
all4c4lt4's Avatar
all4c4lt4
imo, you should port the heads. I doubt you'll come close to 400 rwhp without doing so. Besides, the bulk of your hp will come from quality headwork. You will have to pull the heads anyway to get them machined to accomodate the springs you would need to use for your proposed set up.
Old Sep 27, 2004 | 04:30 PM
Zix's Avatar
Zix
Getting 400RWHP out of an LT4 without porting the heads is very doubtful. And if you do get it, it will be all peak power with very little on the low-end. You should also take a look at the GM847 cam, that cam has been used by a lot of LTx F-body cars with very good results.
Old Sep 27, 2004 | 07:37 PM
1996man's Avatar
1996man
has anybody gotten close to 400rwhp with an LT motor without stroking or much head work?
Old Sep 27, 2004 | 07:53 PM
STL94LT1's Avatar
STL94LT1
No way, not possible.
Old Sep 27, 2004 | 09:26 PM
1996man's Avatar
1996man
i am inclined to disagree since nathan got 38X with only minor porting to LT1 heads and the hotcam which isnt really that aggresive in the way of performance cams. maybe i am wrong
To Paging Nathan
