84 timing question
Do you have the helms manual? It might address this problem directly.
However, the rebuilt distributor might be the problem, or, the remanned computer....
base timing, I think, should be down around 6 degrees
My similar problem, years ago, turned out to be a faulty ECM. I identified it, after checking everything else, by swapping in a borrowed ECM that I knew was in good working order.
Easiest way to diagnose this is to hook up a real-time data logger, like Diacom, etc., then you can see if one of the sensors is out of range.
I suspect 02 or coolant temp sensors, but I'm not big on just changing parts in the "hope" of hitting on the malfunctioning one.
Jake
Do you have a scanner so you can see what temp this sensor is reading and compare it to the dash temperature indication? Note that the dash indication and the ecm use two separate temp sensors.
The alternative is the remove the sensor and test it in hot water with a digital ohm meter. The temp vs ohm charts are in the shop manual.. I can post them if required.
How many miles are on this motor? If you have over 100K on it, your timing chain needs to be replaced. Mine was so loose the motor was loping all over the place and idled like crap. Also couldn't keep it timed correctly. Replaced the timing chain, and now it idles much better, has more power, runs smoother, and the ignition timing sticks dead on.
It starts to run smoother at around 150 degrees because it's going into closed loop.
Are you getting any codes?
It sure would be nice to know more about that cam. Does the widow have any old receipts, or can she send you to whom ever put the engine together?
The only people that can Extrude Hone anything thing, is Extrude Hone. I am aware of one guy that had his Crossfire intake Extrude Honed. AFTER it was ported, they charged him something like $700.00 for the job. For now, your need to get it running properly. THEN you can pull the manifold and port it yourself for a dramatic improvement in performance.
RACE ON!!!
