Fuel cell
I'm to the point of considering going with a fuel cell. Has anyone done this on a C4? If so, where did you get it???
http://www.angelfire.com/theforce/corvette
-Jeb
All of the immisions are gone, and the return vent tube on the top of the tank has a cap on it with a clamp.
I'm wondering if it is leaking between the plastic liner and the steel of the tank.
We've gone as a far as to talc around the weld to see if there is any moisture (from gas), and everything looks fine. I agree -- if you can smell it, there is a leak. FYI -- I did switch over to a vented cap, but it holds pressure. I don't think that is the problem.
The fuel system as you can see has all been changed over. I'm running a 10 -AN line up to the regulators, then a split 8 -AN to the fuel rails.
If it is the tank, I would like to stuff a fuel cell up underneath the car. But I can tell that is going to take a lot of fab work.
Jesse is still working on my chip -- I just sent it to him again yesterday for more tuning. This project is never ending
