LT1 Missing/Backfiring..
Old Sep 28, 2004 | 08:20 AM
Z06_BluByU's Avatar
Z06_BluByU
Default LT1 Missing/Backfiring..
Sometimes after an extended drive (over 30+ mins) the car starts to miss then after while of missing, backfires (muffled - not the loud pop). I'll let the car sit for a few hours and take it to the store and it rides fine.. it also doesnt seem to have a problem in the morning on the way to work (30+ min drive)... I'm thinking maybe the MAP sensor..
BTW: the Car is a 1993 LT1 Speed density ECM.
Old Sep 28, 2004 | 12:59 PM
bogus's Avatar
bogus
hm. a heat soak related miss.
Miles on the opti? Just asking!
I would check the coil wire and coil.
Old Sep 28, 2004 | 03:30 PM
Z06_BluByU's Avatar
Z06_BluByU
42k miles on the opti..
Old Sep 28, 2004 | 03:42 PM
mikey whipreck's Avatar
mikey whipreck
not getting any codes?
Old Sep 28, 2004 | 03:57 PM
sraft's Avatar
sraft
Hmmmm, sounds a lot like the problems I was having last year! I had a O2 sensor that would fail intermittently (not the typical way they fail). The car would drive great for 20-30 miles, then start to misfire under load.
good luck hunting
Old Sep 28, 2004 | 08:51 PM
Z06_BluByU's Avatar
Z06_BluByU
I hooked the car up to my laptop.. everything looks normal.. although it was running like dog dung... the 02 sensor readings were sweaping like they were supposed to and the BLMs were right on target.. timing looked good and no knock retard.. also no DTC codes.. I pulled the coil wire and the end that goes into the opti loked a little toasted.. so i replaced it.. it seems to run good now.. but its had a few hours to cool off.. i guess we'll find out tomorrow on the way home or at lunch!
Boy, I sure like the ECM and FI when tuning..etc... but for old fashioned reliability I like the old days better with glass fuse's, Early HEI, 8 spark plug wires, a tach wire a fuel line and 400+ cubic inches with a 8 track..
Old Sep 29, 2004 | 12:54 PM
Z06_BluByU's Avatar
Z06_BluByU
NOPE. that wasn't it... ARGHHHH ok, this is pissing me off! Can anyone recommend a ignition diagnostic procedure?
Old Sep 30, 2004 | 12:17 AM
jdawgC4's Avatar
jdawgC4
How do you hook up to a labtop and what are the estimated costs for hardware and software if you dont mind answering.
Old Sep 30, 2004 | 12:27 AM
bogus's Avatar
bogus
There are a number of options for software... to give you an idea, EASE, available from www.obd2.com, is about 320.00 - software and cable.
Craig Moates has some options, too.
http://members.tripod.com/moatesenhe...mecm/index.htm
bogus's Avatar
bogus
Do you have the helms manual?
If not, we can always talk by phone and go over the testing processes.
I have a 92 manual, the cars are essentually the same.
Old Sep 30, 2004 | 12:25 PM
Z06_BluByU's Avatar
Z06_BluByU
Thanks for such a generous offor bogus! I've got a helms manual and started peaking through it.. i found the section on ignition.. wow are those things complicated to navigate through.. I'll post an update of my results tonight
Old Sep 30, 2004 | 12:46 PM
bogus's Avatar
bogus
post questions!
The ignition isn't as complex as you think, really.
Old Sep 30, 2004 | 12:51 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Have you tested the coil yet?
Old Oct 1, 2004 | 09:58 AM
Z06_BluByU's Avatar
Z06_BluByU
ok last night I checked the fuel system as outlined in helms.. everything checked out ok... next I moved to the ignition system.. it was on of the C- tables.. I forget which one.. C-3 I think or C-2 the one on how to check the DI system.. I hooked my spark tester up to a wire and plug and turned the motor over.. got spark and lots of it.. also no MIL's are being set.. I think I have a bad wire or plug.. I'm gonna pull them all and inspect tomorrow am.. does this sound logical?
Old Oct 1, 2004 | 01:41 PM
bogus's Avatar
bogus
very logical.
I think you are getting close.
How old are the plugs and wires? Which brands?
Old Oct 3, 2004 | 09:50 PM
Z06_BluByU's Avatar
Z06_BluByU
Plugs are A/C delco Platniums..wires are NAPA premium 7mm.. I pulled the driver side and noticed the #1 wire was corroded where it connected to the Opticrap.. also, I noticed a white discolored area on the #5 area.. I think it was arcing.. I replaced all four wires on the driver side.. and took ti for a test run.. although i didnt run it long enough to see if the ehat soak problem was gone (i'll do taht on the way to work tomorrow) I did notice my radio noise on AM channels is gone!! maybe i'm on to something.. maybe not.. will post results of the ride in to work tomorrow am..
Thanks guys!
Old Oct 3, 2004 | 10:36 PM
bogus's Avatar
bogus
keep it up!
I recommend NGK or Denso plugs and Taylor wires.
Old Oct 4, 2004 | 08:30 AM
Z06_BluByU's Avatar
Z06_BluByU
ok.. that wasn't it.. damit!! I think I'm gonna pull the opti off and replace the cap and rotor... dam thing!
To LT1 Missing/Backfiring..
