A/C eliminate - belt length?
Old Sep 30, 2004 | 08:57 PM
Z-PDX's Avatar
Z-PDX
SUCCESS!!!!!!
The NAPA part number is 060680. The lenght is 68.5 inches.
I wrapped over the tensioner with the ribbed side down. Works GREAT!
I am now searching for a 3" diameter ribbed pulley to replace the flat one with.
The passenger side looks so much better without all that cr@p on there.
I now need to plug the A/C fittings. They are NPT right?
-Z
Old Oct 1, 2004 | 08:26 AM
Carl90's Avatar
Carl90
SUCCESS for me too!
I have March underdrive pulleys, which required a different belt from the stock 90' and 91' belt.
I measured 66"-67" using an old belt, which I cut. I bought a Dayco Poly Cog 5060675. It works fine using the reroute trick. I think that I will retain the stock flat tensioner pulley for now and monitor the ribs for wear.
Thanks everybody for the help.
I picked up 20 RWHP from the mod...oops forgot I am not a vendor...just kidding.
Old Oct 1, 2004 | 08:38 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Do You have any pics of the routing of the belt?
Old Mar 22, 2021 | 03:35 PM
Greg Crane's Avatar
Greg Crane
1st Gear
Originally Posted by Upstate
Makes physical sense , but not logical. I have heard on this very forum as well you can indeed dump your AC and go with a shorter belt, but on 84's only.
what about 1989 Chevy corvette will just getting a shorter belt work on eliminating the a.c. Compressor that it log
​​​locked uped
Old Mar 24, 2021 | 05:32 AM
Bill Chase's Avatar
Bill Chase
​​​locked uped
you're responding to a post that has had no activity in over 15 years. I strongly suggest varying your wording as you search google, there are numerous posts here dealing with ac delete
