Wondering how many guys around are running solid roller setups for the street. I know Solid roller cams are not recommended for the street because of lubrication issues but would like to see who has experience with it. I don't really care of valve adjustment every so often but more intersted in reliability factors. I would like to hear your pros and cons because I am seriously thinking about going solid roller in my SC 377 due to the valve float I get at high rpms.
If you guys can post here along with the specs of your motor, cam, and rpms you are pulling I would appreciate it.
im running a soild cam in my motor and i drive my car all over . 250 miles a week. and its fine
434 215cc afr ported and opened up to 230cc
250 260 @50 650 lift
11.1 comp
super vic jr intake converted to EFI
4000 stall Neil Chance Torque Converter
artcarr 700 r4 trans break
392 dana 44
11.1 comp
392 dana 44
What kind of rpms are you pulling?
What kind of engine management are you running?
250 miles a week with that cam and 4000 stall, you are nuts!
I have a Comp Extreme energy 248/254. About 6500 rpm is as high as I take it. I haven't had any problems, but it only gets driven a few thousand miles a year. But the miles it gets are usually hard miles!
I have a Comp Extreem energy 248/254. About 6500 rpm is as high as I take it. I haven't had any problems, but it only gets driven a few thousand miles a year. But the miles it gets are usually hard miles!
Do you know the max rpm for your cam? Wondering if that cam goes in my 377 if I would be able to see close to 8000rpm?
The big problem with solid roller cams in street applications, is the radical lobe ramps, and the strong spring pressures needed to control the valve train. If you select a "street roller" or one with similar specs to the cam you have now, and keep the spring pressure reasonable, it will likely survive street usage.
RACE ON!!!
Would TPI 421's cam be too radical for the street?
More than likely, yes. One can't tell from that info. The problem with longevity isn't in the duration. It is the RATE of valve opening and closing. The RATE of lifter acceleration will largely be a function of lift AND duration. It is the RATE of opening and closing, that requires the durability killing, stong, spring pressures.
That IS an awful lot of duration for a 377 engine. But I make that comment from a drive-ability stand point, rather than as a reliability issue. Remember, tpi 421 vette's engine has 45 cubic inches more than yours. If I were you, I'd get on the horn with a few cam grinders. Tell them what you have and what you expect. They are best equipped to advise. You may have to call more than once. You'll soon know when you're talking to the wrong person.
Do you know the lift of your cam with 1.6RR?
I don't think my cam in your 377 would make power to 8000 rpm. My peak hp on the dyno is about 6200-6300 rpm. I would guess this cam in your motor would make peak hp on a dyno around 6600-6800 rpm. It would probably pull to 7000 rpm strong. If I remember right, my lift with 1.6 rockers is about .600 and .620. You will need more intake duration if you want to make power to 8000 rpm. Also... this cam only requires springs with about 160 seat/420 open# pressure. So I think it would hold up pretty good on the street.
Thanks for the replies guys...anymore out there???
If I remember correctly, isn't DieL running a solid roller in his stroker?
I've been running TPIS's 701 cam for about 10000 miles now (246 dur @ .050/ .572 lift with 1.5's).
adjustment isn't bad, I do it about twice a year (only drive in summer).
I'm using the stock computer, but I only go to 6600rpm so it works fine.
I don't think I'd trust the stock ECM for 8000rpm since it only lets you adjust air/fuel to 6400rpm @ WOT (thats MAF system, don't know about speed density).
the biggest problem I see with a 8000rpm (street) fuel injected motor is injector size, they would have to be big enough to supply fuel up top (very small time window @ 8000rpm) yet still be driveable and idle decent.
I have mine idling at 1000rpm, it idles smoother and I figure it helps lubricate the roller lifters at idle.
If you've been floating valves with your old cam I'd say go ahead and try a solid roller, even if you have to replace lifters once and awhile thats still cheaper than bending a valve or worse.
you might think about limiting the max rpm to something more like 7200-7400rpm, it might make it easier to tune and live with.
RJ
RJ
Chriswtx, That intake looks very nice, would love to see some numbers when you get some miles on the motor. Did you make that intake yourself?
RJ,
Thanks for the reply. I am not really worried about tuning or injector size because I am running the DFI gen VII. Have you heard about modifiying hydraulic roller lifters to act like solids at high rpms? I was told a company does that, if that's the case it might be a better way for me.
The intake was in my original plan. I bought it when I started the project and planed on converting it to fuel injection myself. It's a Holley Prodominator Tunnelram. I was afraid I would screw up the welds so I sent it to Jeb Burnett to do the conversion to fuel injection. It came out really nice. I portmatched the runners to my heads which are portmatched to Felpro #1207. Also rewelded the headers and portmatched them to the heads, then sent them to HPC coatings. Everything turned out nice. Hope to have it to the dyno in a month or two to check the A/F ratio and HP levels. I am also going to see what it does in the 1/4 mile for fun. I'm not much of a dragracer though. I will be happy with anything above 425HP to the wheels.
quote/
Have you heard about modifiying hydraulic roller lifters to act like solids at high rpms? I was told a company does that, if that's the case it might be a better way for me. /quote
nope, unless your talking about roades (sp?) lifters, I remember they made some type of lifter that bleeds off more at low rpm for better streetablity, thats been awhile.
I don't think I would trust any "hyd roller lifter" above 6500rpm, typically Hyd lifters are heavier than solid lifters (so you'd need more spring pressure to keep it in check at high rpm), valvetrain weight is your enemy at high RPM. if you want to turn 7000+ rpm you only have two choices in my opinion: solid flat tappet or solid roller.
listen to CFI-EFI, talk to the cam tech pro's. the 377ci has been around for quite awhile and there should be lots knowledge in that area.
