Roller rocker questions
Old Sep 30, 2004 | 10:25 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Roller rocker questions
I'm sure this has been asked before....how hard are roller rockers to install? what will they cost, and how much HP can be gained on an L98?
Old Sep 30, 2004 | 10:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On an early L98 you can install 1.5:1 RRs pretty easily but 1.6:1 requires removing the heads to machine the head slots that serve to guide the stock push rods.
On a late L98 ('88 and later and maybe on '87) you can directly install 1.5:1 RRs but to install 1.6:1 RRs you need to remove the stock guide plates for self aligning RRs or install hardened guide plates & push rods for non self aligning RRs.
Cost of Pro Magnum RRs is about $300 for self aligning or for non self aligning and other parts. The installation is quite simple to do.
However, when installing 1.6:1 RRs it's wise to install new springs and keepers this drives up cost a little and degree of difficutly more than a bit.
With a stock cam you can expect to gain about 10chp with 1.5:1 RRs and maybe 15chp peak with 1.6:1 RRs.
My installation cost about $600 since I not only did 1.6:1 ProMagnums but also, valve seals, springs, Ti retainers, 10deg locks, hardened guide plates & push rods along with some shims and light assembly lube.
Old Sep 30, 2004 | 11:23 PM
vader86's Avatar
vader86
Youll gain about 15 at peak.
Old Oct 1, 2004 | 08:27 PM
rrubel's Avatar
rrubel
I did 1.6's on my early 86 (CI heads) and there was no interference with the guide slots. I did need to grind down the drip tabs on the valve covers (not all the way, just about 1/4" or so).
[RICHR]
Old Oct 1, 2004 | 11:00 PM
JAKE's Avatar
JAKE
[RICHR]
Yep, and I bent at least half a dozen exhaust pushrods on the same engine.
Pulled the heads, had the slots elongated and it was good to go.
Jake
Old Oct 2, 2004 | 08:24 AM
rrubel's Avatar
rrubel
Jake
Dunno what to say... put 8k miles on the setup including long trips, track days, and dragstrip runs and didn't bend a thing. Only reason they're not still there is because I've got a roller block now.
Perhaps it was the brand I was using. Different design?
[RICHR]
Old Oct 2, 2004 | 08:48 AM
FlyboyZR1's Avatar
FlyboyZR1
[RICHR]
Some people say 1.6's will work on the iron heads, and some people say they won't.
What brand were you using?
Old Oct 2, 2004 | 12:15 PM
rrubel's Avatar
rrubel
CAT's - Cal Auto Transpeed. Don't remember the particular part number, though.
[RICHR]
Old Oct 2, 2004 | 12:29 PM
CFI-EFI's Avatar
CFI-EFI
It isn't the rocker involved, as much as it is the heads. The slot that guides the push rods in the iron heads is cast in. Hardly a precision process. One should first CHECK all of the push rods for interference with the slot. Some will clear, others won't. It is only a problem at the outer (stud) end of the slot. The slot CAN be lengthened, if necessary. Don't make it any wider.
RACE ON!!!
Old Oct 2, 2004 | 12:33 PM
JAKE's Avatar
JAKE
I was using some blue aluminum RRs, but can't remember if they were Proforms or Mr. Gasket.
Camshaft valve lift may have a bearing on the problem too. I was running a CompCams Xtreme Energy flat-tappet hydraulic cam at the time. Valve lift was somewhere in the .480 range.
I had read about the possibility of pushrod interference problems in TPIS' Insider Hints book and another mag, so when I took the heads to the machine shop for freshening, I told them to elongate the slots.
Well, they only did the intakes and I didn't check when I got the heads back. From years of experience, I KNOW to check behind the work of others, but for some reason in this case I didn't - AND I PAID THE PRICE TOO.
In addition to being bent, I could see the well-worn areas on the pushrod where it was riding against the head in the slot. Nice and shiny with lots of metal gone.
I've read, too, that some haven't had a problem; wish I had been one of them. Pulling heads isn't my idea of a nice way to spend the day.
Jake
Old Oct 2, 2004 | 01:51 PM
rrubel's Avatar
rrubel
I still had the stock L98 cam. Don't know the lift, but I'm sure it was less. The roller rockers were more an experiment than anything else; they didn't (by themselves) appear to do much other than make the valvetrain somewhat quieter. The touch more power (measured at the drag strip and by a GTech, neither totally reliable methods) I attribute more to replacing/adjusting high-mileage parts than anything else.
I don't think pulling heads is *anybody's* idea of a nice way to spend the day .
[RICHR]
To Roller rocker questions
