What do the runners do?
Old Oct 2, 2004 | 10:38 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default What do the runners do?
This may sound like a stupid question but what are the runners for?
Old Oct 2, 2004 | 10:41 PM
scorp508's Avatar
scorp508
Lets air travel from the plenum into the intake manifold.
Old Oct 2, 2004 | 10:51 PM
90Indy's Avatar
90Indy
Your runners are located between the plenum and the intake manifold. Their purpose is to direct the air flow coming in from the plenum to the intake manifold and from there into the head to support combustion. Since you have a fuel injection fuel delivery system you do not have a carb sitting atop the intake manifold so the air takes a somewhat longer trip to the combustion chamber. Hope this helps.
Take care.
90Indy
Old Oct 2, 2004 | 10:53 PM
vader86's Avatar
vader86
The runners are the tubes leading from the plenum to the intake manifold. They are there to let the engine breathe.
Their length is what amplifies your low-end torque.
Old Oct 3, 2004 | 12:52 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default yep exactly what they said
Vader hit that on the head....
The length is what matters....this is why different designs equal more or less torque in a certain band.
Longer the runners...up to a point....more torque in the low rpm band....why L-98's are notorious for having low end grunt....but nothing after 4500. The runner length is like a tuning fork for our cars.
MiniRam and SuperRam use smaller runner lengths....so they give up a little in the lower end but allow the engine to pull harder in the higher RPM range.....
its really pretty cool stuff
To What do the runners do?
