Datamaster does not even work with there own soft ware.
I don't know if it would work with tuner kats I haven't tried yet.
When I get my car back I 'll give it a try.
Trans 3-4 gear blew out normal for a 4l60e.
Great glad to see you got it going.
I would think all the other software that supports your 165 setup would also work. To interface with the ecm a voltage shifting device that can send and recieve and a 10k resistor is all thats needed. (This is what datamaster requires too). I built my own from a max233 ic board that I had for other uses. It works on all of the other software.
