Bad MAF?
Old Oct 3, 2004 | 10:33 AM
TheCar's Avatar
TheCar
Default Bad MAF?
Anyone know if it is a charactaristic of a bad MAF to mess up after a restart? Clear code 34 & let it sit overnight and its good until I shut it off again.
Old Oct 3, 2004 | 11:16 AM
vader86's Avatar
vader86
Since you have an 85, you wont replace the 2 relays on the firewall, they arent there, despite what people here will try to tell you.
You have either a bad Burnoff Module or MAF sensor, assuming that there are no wiring shorts. Neither is cheap.
Old Oct 3, 2004 | 11:28 AM
CFI-EFI's Avatar
CFI-EFI
Follow the trouble shooting charts in your HELMS manual, before you start throwing parts (money) at it.
RACE ON!!!
Old Oct 5, 2004 | 02:55 AM
Mo_Bandy's Avatar
Mo_Bandy
I found easiest maf test "assuming the burn off relay isgood"...
Unplug the maf and see if the engine runs smooth both my 87 and 89 had a MAF problem...
If it runs smooth ( it will set a code being unplugged) chances are good it is the MAF....
AS mentioned above the Helms has a heck list... also they run about 250 bucks as i recall...
Mo
Old Oct 5, 2004 | 08:18 AM
TheCar's Avatar
TheCar
Thanks for the info. Its definately a bad MAF. I've found prices from $165 [rebuilt] to $450. I think I'm goning to try one of the Granatelli adjustable Maf sensors from Summit.
To Bad MAF?
