radio noise
Old Oct 3, 2004 | 08:20 PM
Clemson Vette's Avatar
Clemson Vette
Default radio noise
i got my heads reworked and all a few weeks ago when i blew a head gasket. it's all runnin fine now, but my radio has a popping noise in it that speeds up with the speed of the motor. anyone know how to stop this? you konw what all they had to take off to remove heads, so what can i do to stop this? did they not tighten up something or what? help please.
Old Oct 3, 2004 | 08:32 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Did they change plugs?? Non-resistor type sparkplugs can sometimes cause engine noise on stereo. Or, perhaps they nicked a plug wire. A plug wire with an imperfection or bad insulation will also cause engine noise in stereo. Other than that it could be a loose ground or bad wire within the stereo system itself.
Old Oct 3, 2004 | 09:31 PM
Z06_BluByU's Avatar
Z06_BluByU
Dave is right on the money... I would bet dollars to doughnuts that the guys nicked a spark plug wire while taking the heads off now its arching.. At night take a spray bottle and mist water on the spark plug wires (of course with no lights on). look for the blue arc jumping.. that'll tell ya what wire is bad.. Also, I'm gonna bet the driver side is gonna be the side with the bad wire because of the goofy routing of the wires under the ASR unit, A/C compressor..etc..etc.. there is mroe stuff for the wires to rub on..
good luck!
To radio noise
