Hurst Billet Shifter question 2
Old Oct 4, 2004 | 07:46 AM
redgb's Avatar
redgb
Default Hurst Billet Shifter question 2
I installed the Hurst shifter this past weekend and it is great.
I used the black 2 1/4 inch Hurst **** with the shiht pattern on it.
The problem I had was that when I tightened the **** to a point that seems solid, the shift pattern isn't lined up. Thought about using a thin jam nut but I haven't had any luck finding the correct nut. Any tricks out there to help me line the pattern up?
Old Oct 4, 2004 | 07:56 AM
LD85's Avatar
LD85
Mine came with a jam nut
LD85's Avatar
LD85
My shifter came with a jam nut and I have the same black 6 speed patter ****, it is tight and does not move.
Old Oct 4, 2004 | 08:07 AM
Strick's Avatar
Strick
Mine came with the jam nut,also. Make sure you really tighten the **** on the shifter, but you'll need the jam nut.
Old Oct 4, 2004 | 09:52 AM
redgb's Avatar
redgb
Thanks for the quick responses. I just called Hurst and they are sending the jam nut. This mod feels good.
Old Oct 4, 2004 | 11:47 AM
Red Tornado's Avatar
Red Tornado
I couldn't find the jam but that was supposed to come with mine. I experienced the same problem, so to recitfy it I used a black rubber washer. **** is now tight as a (you know what) now!
Old Oct 4, 2004 | 08:46 PM
JB666's Avatar
JB666
I just ordered my Hurst setup. Help me out here , does everyone that has the Hurst **** installed have the threads showing on the shaft?
Old Oct 4, 2004 | 08:59 PM
LD85's Avatar
LD85
Mine show @ 1/2 inch
Old Oct 5, 2004 | 02:43 PM
redgb's Avatar
redgb
Mine shows about 3/8" of thread without the jam nut. I expect the jam nut will cover the 3/8" of thread or most of it.
Old Oct 5, 2004 | 03:32 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I like the stock ****. Although the ball looks kinda old school.
Old Oct 5, 2004 | 03:58 PM
Red Tornado
It does, but if you like old school its cool, a classic look Just like the old school GMPP ProForm chrome valve covers I'm getting as well
To Hurst Billet Shifter question 2
