Speedo Gear Question
Old Oct 4, 2004 | 05:00 PM
dcc4's Avatar
dcc4
1st Gear
Default Speedo Gear Question
hey everyone,
I am new to the forum so bear with me. I have got a 91 corvette I swapped out the auto matic for a stock zf 6 speed and changed the 2.59 rearend to the 3.07 out of anouther corvette. I have stock rims and tires. My question is what color or what do I need to do to get my speedometer to read correct. Hope someone knows the answear.
Old Oct 4, 2004 | 05:29 PM
LD85's Avatar
LD85
I dont think the 3:07 and the ZF 6 speed will work unless you havea green driven gear and get a RED drive gear and have it bored out larger to fit the ZF ouput shaft.
Bill at www.zfdoc.com was abotu to make some of these but I could not wait and bought a www.dakotadigital.com speedo calibrator.
I have the ZF with the 3:07's too, at least for now.
Old Oct 4, 2004 | 08:42 PM
CFI-EFI's Avatar
CFI-EFI
Is that the stock trans for that year car? You probably don't know what the donor car had for gears. You need a red, 17 tooth, drive gear, pn, 8640517. A green, 42 tooth, driven gear, pn 25513049. And a 10456089 VSS, for a stock '91 6 speed. The VSS goes with the driven gear. If the one in there now has 42 or more teeth, the VSS won't have to be changed.
RACE ON!!!
Old Oct 4, 2004 | 09:03 PM
LD85's Avatar
LD85
Just remember, the red gear has an ID that is too small for the output shaft.
Old Oct 4, 2004 | 09:57 PM
CFI-EFI's Avatar
CFI-EFI
OOPS! I double checked. I don't show a 17 toother for the 6 speed. Maybe I can figure out a way to use the availble 15 tooth drive gear tomorrow.
RACE ON!!!
Old Oct 4, 2004 | 10:16 PM
aklim's Avatar
aklim
At what point do you change the VSS? I have a 91 with 3.07 gears and if I were to go up to a 3.45 or a 3.54, can I leave the VSS alone?
Old Oct 4, 2004 | 10:18 PM
MrRenoman's Avatar
MrRenoman
I'm pretty sure 3.07 and lower gears use the same speed sensor, the one that is really hard to buy new.
Old Oct 4, 2004 | 10:21 PM
aklim's Avatar
aklim
So what do you do when you go from a 3.07 to 3.45 or 3.54? Which VSS do you use? I know you have to change the driven and driven gear to say a 15 tooth drive and 41 (based on calculations) driven but what else?
Old Oct 4, 2004 | 10:31 PM
MrRenoman's Avatar
MrRenoman
Do you want a part number? If you have a 3.07 reuse the sensor and install new gears in the trans and on the sensor. I hope that's what you're asking. I have a part number somewhere. There are 2 numbers, one was superceded by the other.
Old Oct 4, 2004 | 10:36 PM
aklim's Avatar
aklim
That is EXACTLY what I am asking. I just got a new sensor for my car based on stock specs so before I install it. I want to make sure that when I change to a higher ratio, I could keep the VSS and just change to a 155 drive tooth gear from 17 tooth.
Old Oct 4, 2004 | 11:03 PM
MrRenoman's Avatar
MrRenoman
Here's a link to a popular site.
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
Here's the part number off my new speed sensor. The number I pulled out of my old 84-87 Illustrated Parts Catalog was superceded by this one.
25007308
BTW, if you have a '91 it looks like it changes part numbers, I didn't realize this til I looked at the web site, hope it helps.
Old Oct 4, 2004 | 11:12 PM
MrRenoman's Avatar
MrRenoman
Doesn't look like I'm any help at all Doh! Sorry! I crack myself up sometimes. Glad I can laugh at myself.
Old Oct 5, 2004 | 06:49 AM
LD85's Avatar
LD85
The only way you can get a match exactly with the ZF and a 3:07 rear gear is to take the RED gear and fill the voids in the sides of the injection molded RED gear with JB Weld etc, let it dry then bore it out on a lathe so the ID will fit the larger output shaft of the ZF. The ZF did not come with a 3:07 option and the RED gear is for the 4+3.
Call Bill at ZFDOC and he will tell you the same thing.
Or you can go to www.dakotadigital.com and buy a speedo calibrator for $75 and make it nearly perfect.
Old Oct 5, 2004 | 03:09 PM
CFI-EFI's Avatar
CFI-EFI
Another way to go is the 15 tooth gray drive gear, you probably already have, a 37 tooth, red, driven gear, pn 25513044, and a 10456088, VSS. I have yet to find a 17 tooth drive gear for the 6 speed.
By the way, the red 17 tooth drive gear fits the 700R4/4L60, as well as the 4+3 transmission.
RACE ON!!!
Old Oct 5, 2004 | 05:22 PM
aklim's Avatar
aklim
RACE ON!!!
MD8 with P275/40ZR17 Tires 3.07 8640517 Red 17 25513049 Green 42 10456091 is the combination I currently have. Just wondering if I could simply switch the drive to 15 and the driven to 41.
Old Oct 5, 2004 | 07:05 PM
CFI-EFI's Avatar
CFI-EFI
For the 700R4/4L60 the 15 tooth, gray, drive gear, is 8642520. MY books show that is all you HAVE to change. My books don't show a 41 tooth driven gear. I DO show that the 42 tooth driven gear and the 38 tooth driven gear use different VSS's, but I don't know where the break is. In other words, I don't know if you have to change the VSS for a 41 tooth driven gear, or not. You can try the 41 toother with your VSS and see if it goes together properly. Upon further review, my book calls for a purple, 43 tooth, driven gear (25513050), with those tires. That gear WILL work with your present VSS.
RACE ON!!!
Old Oct 5, 2004 | 07:07 PM
aklim's Avatar
aklim
RACE ON!!!
Then, you sir, have done me a great service.
Old Sep 2, 2019 | 08:42 PM
Bigdick's Avatar
Bigdick
I have 345’s in my 89 15 tooth drive gear and 42 tooth driven gear. If he has 307 gears I believe he will only need to change driven gear from 40 tooth to 42 tooth. I had to find a 307 or higher VSS for mine.
Old Sep 2, 2019 | 10:37 PM
Bigdick's Avatar
Bigdick
Being new to this forum, may explain that I wouldn’t know that a link would be so old and still visible. As far as your comments, totally unnecessary, but you can continue to hide and be derogatory. People like you give good corvette owners a bad name. Enjoy your day.
To Speedo Gear Question
