Driver door is dropping 84
Old Oct 4, 2004 | 08:29 PM
Brimis's Avatar
Brimis
Default Driver door is dropping 84
The driver's door on my 84 is dropping. You can see the trim on the door and quarter panel are off quite a bit and the door will not always close on the first attempt. What generally goes first, the door hinge or door hinge pin and bushing? Should the hinge, pin and bushing be replaced?
Old Oct 4, 2004 | 08:31 PM
bogus's Avatar
bogus
hinge pin & bushing... they ain't expensive, either... a couple bucks!
