headlight click
Old Oct 5, 2004 | 08:15 AM
lakerat's Avatar
lakerat
Default headlight click
After replacing the bushings on my left front, I started getting a clicking sound occasionally after the light closes. Sometimes, it even happens when turning from Aux. to off.
Does anyone have an idea what could be causing this?
Old Oct 6, 2004 | 07:49 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
There is a locking nut on the headlight motor worm gear adjusting screw. Did you remember to tighten it?
You have to tighten it to the EXACT number of turns it was loosened during your bushing installation or it will often result in the clicking you're hearing.
Old Oct 6, 2004 | 07:58 AM
lakerat's Avatar
lakerat
Thanks, I wish I had found the tech tip before taking on the job. At the time, I couldn't access them, so I removed the motor. Broke the screws. Drilled out new ones. And, never touched the worm gear adjustment screw.
I'll give it a turn...
To headlight click
