1985 Just Quit!
Old Oct 5, 2004 | 02:35 PM
nyjack3's Avatar
nyjack3
2nd Gear
Default 1985 Just Quit!
Hi I am new this forum so be kind. My 1985 with standard transmission, with about 95,000 miles on it. While traveling at about 65 mph it JUST QUIT running. It back fired about 6 times and blew lots of black smoke out the exhaust before I took it out of gear and coasted to a stop. It will crank over but not fire, checked for spark... none. Cap, rotor, wires and plugs are all new a few months ago.... No fuses blown, tested the coil and the pickup coil in the distributor both seam to be OK. Checked all the connectors to the dist. Replaced the ignition module but still no spark! I was 150 miles from home and had to flat bed it home.... Anybody got an ideas?? Thanks.
Old Oct 5, 2004 | 02:51 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
sorry to hear that... that stinks!!! I wish I could help ya, but all the things I'd suggest... you already tried. Sorry about the ride.
Old Oct 5, 2004 | 03:34 PM
comp's Avatar
comp
doesn't sound good ,,open cap and see if rotor turns when engine is turning (do by hand) also pull the plug's
Old Oct 5, 2004 | 03:36 PM
nyjack3's Avatar
nyjack3
2nd Gear
Ya checked that too, the rotor turns
Old Oct 5, 2004 | 03:40 PM
MrRenoman's Avatar
MrRenoman
It seems like an ignition problem. You say it backfired and was letting out black smoke. To me, that means you were getting fuel. Make sure you have 12 volts dc at the cap. Inside you'll see some wiring. These cars are getting old now and the wiring could be failing and shorting to ground. I replaced my pickup coil just recently, and it fell into my hands in pieces. If you are having trouble isolating the trouble, borrowing a known good distributor is do-able.
Old Oct 5, 2004 | 05:20 PM
Vetterin's Avatar
Vetterin
Try checking that coil one more time.
Old Oct 5, 2004 | 10:34 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Check the rotor to see if it has a pinhole in the center or a burnt spot. Electricity will take the shortest path, the distributor shaft to ground. Ron B.
To 1985 Just Quit!
