Please Help
Old Oct 5, 2004 | 08:47 PM
Epyon127's Avatar
Epyon127
Default Please Help
So two weeks ago the car started to need a couple tries to start, but always did, then I get home and try and it is dead no more than a clunk when you turn the key, so I replaced the battery still no go, so I checked the fuel pressure and sure enough when you turn the key the pressure goes up then goes away immediatley, I pulled the FPR and there was a 3/8 inch hole in it, so I sent it back to holley and they fixed it, in the mean time I had to take each spark plug out and empty the gas from each cylinder, I replaced the plugs, checked the wires, changed the oil, and installed the fixed FPR. Now the car runs but has a stumble and vibration it never had before. What is it? I have good pressure at startup and running, what gives? Thanks for any help
Old Oct 5, 2004 | 09:02 PM
jabez's Avatar
jabez
opti?
