oil pressure
Old Oct 5, 2004 | 11:28 PM
shawanokid's Avatar
shawanokid
Default oil pressure
i have a 86 vette and i was wondering where should my oil pressure be at when i'm cruising at 65mph. also where should it be when the car is warm and ideling?
Old Oct 5, 2004 | 11:36 PM
vader86's Avatar
vader86
Anytime your foot is on the gas, it needs to be over 50psi. At full throttle it should top 60psi.
At warm idle it should be about half of that.
Old Oct 6, 2004 | 01:22 AM
vettenut85's Avatar
vettenut85
sounds excatly the way my 85 reads.
Old Oct 6, 2004 | 09:44 PM
shawanokid's Avatar
shawanokid
most of the time i'm running somewhere between 65 and 80 psi. is this to much or is it acceptable?
Old Oct 6, 2004 | 10:17 PM
vader86's Avatar
vader86
80psi indicates a problem with the oil pressure sender or one of the wires leading to it, because thats the max it can read and its not supposed to be that high.
Old Oct 7, 2004 | 08:52 PM
shawanokid's Avatar
shawanokid
thanx for the post. to me 80 psi seemed high. at least now i have a place to start.
To oil pressure
