I had an incient while working on my car and lost a pretty good bit of trans. fluid. So my question is how much fluid does a 91' auto hold? And can I mix some B&M trickshift with whatever is left in the tranny? TIA
I donno about mixing fluids, but I suspect it isn't a problem. Without pumping all the fluid out, you can't drain it all... so some of the old has to stay.
My 95 A4 took 14 1/2 quarts of Mobil synthetic ATF. They will mix but why use a clearly inferior (standard) ATF fluid than the Mobil 1- especially without using an external ATF cooler?
14 1/2 quarts - thats right at 3 1/2 gallons, I don't think it holds that much fluid. I really need to get this car back on the road, supposed to head down to Cruisin The Coast Thurs. aft. Thanks, Dave
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Most any Good brand name transfluid that's compatible with your spec.
I think it's Decron III now for yours.
I use a non synthetic.
My trans get rebuilt every two-three years and I flush it every year.
But then I pound the crap outta mine.
In my truck, I use regular trans-fluid as well. I flush that every 25,000 miles.
I have nothing against syn. It's just that in my corvette I find that regular trans fluid bites better giving me the crisp shift I need.
My two cents, again
Matt383
