Electrical Wizard needed..VATS
Old Oct 6, 2004 | 11:24 AM
PUREC4's Avatar
PUREC4
Default Electrical Wizard needed..VATS
Found my problem to be broken wire at switch that can't be repaired. Anyone know the value of resistor needed to by pass switch for now?
Key value is 2 by reading the ohms.
Old Oct 6, 2004 | 11:47 AM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Take your key to a chevy dealer and they can read the number of Ohms off your key. Then go to radio shack and get one.
Or since you know the key code value is 2 call the dealer and they may have the chart to tell you the same info.
Or call Mid America and get a VATS bypass for your car. I think its about 28 bucks. You will need they key value for that when ordering.
Hope this helps.
Matt383
Old Oct 6, 2004 | 12:14 PM
PUREC4's Avatar
PUREC4
Thanks Matt, But need the car now. Can order from MA but need to bypass for now to get to work. Thanks
Old Oct 6, 2004 | 12:24 PM
jfb's Avatar
jfb
Measure the pellet resistance with an ohmeter (a digital one) and buy the nearest standard value (within 5%) 1/4 watt 5% resistor from Radio Shack and connect it to the wires going to the VATS module.
Old Oct 6, 2004 | 12:26 PM
bogus's Avatar
bogus
yea, you will need a new switch, ain't that fun to reach!!!
Old Oct 6, 2004 | 12:30 PM
PUREC4's Avatar
PUREC4
On my way to Radio Shack. Hope they have someone who has at least three working brain cells. Called them left me on hold to 10 min. Been calling back for over a half hour..left the phone off the hook..... GOD help.....Guess he'll be able to have a quiet day Cya in a short
Thanks all
Old Oct 6, 2004 | 12:34 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Key #2 is 523 ohms
Old Oct 6, 2004 | 01:36 PM
PUREC4's Avatar
PUREC4
Huston we have a GOOOOOOOOOOO!!!!!!!
What a pain, but thanks to all who helped. Used a 330 and a 220 in line , and attached to the wiring plug from the switch. Off to work
Cya
Old Oct 6, 2004 | 05:21 PM
munday's Avatar
munday
click here for key number to ohms
you can use a resisteor directly in the line, radio shack doesn't carry anything from 650-1050 I believe.
To Electrical Wizard needed..VATS
