Camber Brace install instructions --??
Old Oct 6, 2004 | 03:25 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Camber Brace install instructions --??
Does anyone have the R&D Camber Brace install instrcutions that they can scan and email to me at cicch95@***.net?
Thanks,
-Rick
Old Oct 6, 2004 | 03:30 PM
Perfusion's Avatar
Perfusion
I don't have a scanner, otherwise I would. Have you contacted Dave @ R-D yet? What step in particular are you stuck at, or do you just need the whole thing?
Old Oct 6, 2004 | 03:34 PM
Wheelman's Avatar
Wheelman
I don't have the instructions but I can help you out....what part do you need help with?
Old Oct 6, 2004 | 03:40 PM
cicch95's Avatar
cicch95
Nothing in particular, I am sure I can get it back in there. I just seem to remember somerhitn about twisting it one way or something. Maybe I am wrong!?!?
-Rick
Old Oct 6, 2004 | 03:54 PM
Perfusion's Avatar
Perfusion
Yeah...you install it from the passenger side of the vehicle with the "wings" pointed down. When you get it slid into the general area, you rotate it so that they line up with the correct holes. A word to the wise - the the driver's side bolt started beforehand. You'll save yourself a lot of time...
Old Oct 6, 2004 | 06:23 PM
cicch95's Avatar
cicch95
Yes, that sounds familar! Thanks!
Old Oct 6, 2004 | 06:53 PM
Wheelman's Avatar
Wheelman
Another thing ill add is that you'll make it easier on yourself if you jack the car up under the front crossmember before you try to slide in the brace. If it happens to be a tight fight like mine was, that extra bit of flex will make all the difference.
Old Oct 6, 2004 | 09:44 PM
cicch95's Avatar
cicch95
Thanks guys! The brace i sback in! Yahoo!
-Rick
To Camber Brace install instructions --??
