dual mass worn or not
Old Oct 7, 2004 | 12:17 AM
Getsom's Avatar
Getsom
Default dual mass worn or not
Hi all,
l after pulling out the dual mass fly wheel l found that the surface is in very good condition, and l belive still OK to use, but the local clutch specialist (who has never see one out of a corvette)told me that the rubber diaphragm between the two masses has too much movement, when laying flat you can twist it with both hands if you try and it will move about .25 of an inch and then locks up.
Can anyone tell if this is OK?
Thanks Gtesom (Australia)
Old Oct 7, 2004 | 03:58 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
There is such a thing as too much movement but I won't have access to my service manual until Saturday. I am sure someone else here will probably be able to help you out before then.
I had a dual mass that "clicked" when hot and made a ratcheting noise when I shut the motor off. When I had the gearbox out while doing the conversion I held one side of the dual mass and rotated it. At the end of the play between the two halves it clicked. To my reckoning this meant the FW was finished. Was your gearbox making any funny noises before you did the conversion?
Old Oct 7, 2004 | 07:15 AM
RichS's Avatar
RichS
The movement to be bad is around 1 3/8" (forget the actual #)from turn to turn. If you only have 1/4" play going in each direction for 1/2" total it is still good.
Old Oct 7, 2004 | 08:26 AM
Ghostpilot's Avatar
Ghostpilot
Sure would be ashame to put a bad disk back in. If any doubt, for just the peice of mind put a new set in.
Old Oct 7, 2004 | 08:27 AM
93Quasar's Avatar
93Quasar
My service manual says 35 mm from stop to stop. I'd reinstall the one you have, especially when you start pricing replacements.
Old Oct 7, 2004 | 08:33 AM
LD85's Avatar
LD85
http://www.dualmassinc.com/
Old Oct 7, 2004 | 10:02 AM
Strick's Avatar
Strick
Originally Posted by ld85
Thanks for the link. Now all we need is someone to repair these flywheels if the backlash is excessive.
Old Oct 7, 2004 | 11:12 AM
LD85's Avatar
LD85
I would assume it could be done maybe the guys above might know something. The elastomer "might" be able to be replaced.
Old Oct 8, 2004 | 12:14 AM
Getsom's Avatar
Getsom
Thanks for the good feed back,
It has a total of 18mm movement stop to stop so l plan on putting it back in, if l can't get the twin plate single mass quite enough.
Later Getsom
To dual mass worn or not
