Adjustable fuel pressure regulator?
Old Oct 7, 2004 | 08:15 PM
Aqua94vette's Avatar
Aqua94vette
Default Adjustable fuel pressure regulator?
On an afpr do you adjust the fuel with the vacuum line on or off of the regultor.
Also I just upgraded to 25lb fuel injectors do I need to run at a different fule pressure besides 40psi. Thanks for all your help over the past few months.
Old Oct 7, 2004 | 09:02 PM
Aqua94vette
anybody?
Old Oct 7, 2004 | 09:05 PM
James94LT1's Avatar
James94LT1
pull the vaccum line off to adjust. Fuel Pressure is a thing that I've always found ya just gotta play with. Seems a little differnt for every car/setup. 38-39 is where my car ran best with the stockers. I am running 30lb injectors now at the same pressure, haven't had dyno time to adjust for optimal setting.
Old Oct 8, 2004 | 01:08 AM
black_89_vette's Avatar
black_89_vette
I did mine by pulling the vaccuum off and plugging the line.
Old Oct 9, 2004 | 02:01 AM
howdo's Avatar
howdo
Default use a scan tool
I just talked someone who does this kind of thing for a living, and they said the only way is to hook up a scan tool drive around and see where the integrator and block learn values are at during cruise. The block learn should be at 128. If not, make adjustments 1 psi at a time, drive around again and check block learn.
I'm not sure if you have a scan tool, but I just started getting into this, and it's way cool. I use the tunerpro RT software and built my own cable. I use the probst corvette fuel injection book to figure out what to look for. I think using a scan tool is the key for sucessful tuning.
I'm not sure if you need to have the vacuum line connected.
Good luck
Old Oct 9, 2004 | 02:11 AM
EPiC Vette's Avatar
EPiC Vette
Old Oct 9, 2004 | 09:41 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
What is the fuel pressure stock for the lt1?
Old Oct 9, 2004 | 11:45 AM
vette95's Avatar
vette95
I think it,s 41-47 psi.
Old Oct 9, 2004 | 12:06 PM
James94LT1's Avatar
James94LT1
Mine was 45 stock, dropped down to 39 and gained 2/10ths and 2 mph at the track. I heard they come a little rich from the factory so lowering the pressure on the LT1's gives ya a little more.
Old Oct 10, 2004 | 01:18 AM
Trizney's Avatar
Trizney
There is a running debate on AFPR used in 94+ due to the way the computer handles fuel. Some say it is not needed.
Old Oct 10, 2004 | 08:10 AM
silver & red CE's Avatar
silver & red CE
The issue is that the 94-96 PCM will adjust the WOT injector pulse width on the fly. The reason why is related to the block learn stuff mentioned in an earlier above. In a 94-96, the PCM adjusts out any HP benefit gained by tweaking the fuel pressure within a few minutes of driving. I guess tweeking the FP works great in earlier Vette PCM/ECM, but not th 94-96 LT1/4.
Eric
To Adjustable fuel pressure regulator?
