Burn valves from open exhaust?
Old Oct 8, 2004 | 02:19 AM
BlkMagik's Avatar
BlkMagik
Default Burn valves from open exhaust?
Ok, so this old mechanic guy tells me that I will burn up my valves if I run without my mufflers without changing the fuel ratio because of lack of backpressure I think. Now I'm no chemist but that didn't sound right. The whole reason it even came up was cuz I am considering buying the muffler eliminators which are just open pipes. If backpressure is needed, wouldn't the cat do the job?
Old Oct 8, 2004 | 02:42 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
He's talking about damage from running too lean, which can burn pistons, valves, etc.
I wouldn't worry about it from running muffler elims though.
I'm running a 2 1/2" front Y, hi-flow cat and cat-back that give very little back pressure with no problems.
However, I suggest you add an AFPR so you can bump fuel pressure a little to better take advantge of increses in air flow at WOT.
Old Oct 8, 2004 | 03:02 AM
BlkMagik's Avatar
BlkMagik
Thanks for the info, I'm glad he wasn't 100% right.
To Burn valves from open exhaust?
