84 dash cluster question
Old Oct 8, 2004 | 08:02 AM
da747's Avatar
da747
Default 84 dash cluster question
anyone know if the 84-89 main instrument clusters are interchangable between years? thank you
Old Oct 8, 2004 | 08:48 AM
rick lambert's Avatar
rick lambert
I know the bulbs are different, you might call Gordon Killebrew and ask him. 1-800-398-3883. $10 per call plus $3. per minute.The 84-89 have the same 32-pin connector along with one 24 pin. But I think there are some differences.
Old Oct 8, 2004 | 10:25 AM
mikey whipreck's Avatar
mikey whipreck
1984 uses a different display then 85-89...
In a 1984 cluster, the tach is different. The whole display uses more colors, and the info panel in the middle is dispalyed slightly differently. I don't know if you could put a newer cluster in place of yours, but they are different.
Old Oct 8, 2004 | 12:08 PM
LD85's Avatar
LD85
Look at the pinouts for each model year the 84 and what you want to buy to see if they correspond. There are two connectors on the Cluster
Old Oct 8, 2004 | 01:20 PM
rsauron's Avatar
rsauron
I have a 84 cluster in my 85 works just fine..
Old Oct 8, 2004 | 04:07 PM
vsocks's Avatar
vsocks
I have a 1988or 89 in my 84. Wanted to upgrade to better electronics and graphics display. The 84's really suck and look like an old Atari game. Works great..Only issue is that the 88 has the up or down shift arrow which will not function in my 84. Everything else is fine!
Old Oct 8, 2004 | 08:33 PM
marlon88's Avatar
marlon88
I just put a 1989 cluster in my brother`s 1984 , works fine !
Old Oct 8, 2004 | 10:39 PM
MrRenoman's Avatar
MrRenoman
I have a used remanufactured '86 cluster if anyone is interested.
Art
To 84 dash cluster question
