how do i remove alt pulley?
Old Oct 8, 2004 | 11:49 AM
redbullapril23's Avatar
redbullapril23
Default how do i remove alt pulley?
How do i remove the alt pulley on my 1996 aut lt1?
underdrive pullies....
Old Oct 8, 2004 | 12:42 PM
Strick's Avatar
Strick
There is a special tool used to pull the pulley off. Go to a Pep Boys or AutoZone and look for it. It's pretty cheap and works well. The tool clamps around the front part of the pulley and uses a bolt to push on the shaft while pulling the pulley off.
Old Oct 8, 2004 | 12:47 PM
krivera's Avatar
krivera
i would always be very careful and put a screw driver in there and back up the nut? but there is a special tool but if you are careful a screw driver will work
Old Oct 8, 2004 | 01:31 PM
redbullapril23
kool!
do i need to hold the alt fan still while i back the screw out?
thanks
Sean
Old Oct 8, 2004 | 03:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I was unable to break the nut loose so waited till the alt needed to be replaced and let the shop use an impact wrench to break the nut free and install my overdrive alt pulley.
BTW, they said that they had to grind down a socket to tighten the nut after the overdrive pulley had been installed.
Old Oct 8, 2004 | 03:31 PM
comp's Avatar
comp
Old Oct 8, 2004 | 03:41 PM
redbullapril23
omg i just brok like 5 of the teen on the alt!!! ugh!!!!
the guy at autozone told me to put a screw driver in it!! that jackass
what should i do i cant get it loose and dont have an impact wrench
Old Oct 8, 2004 | 04:18 PM
drumboytroy's Avatar
drumboytroy
Most mechanics will use an impact wrench. Very quick and easy. Just don't over-do it.
Oops....you said under drive......not sure. I know on regular alt it's right off and right on in a snap.
Old Oct 8, 2004 | 05:50 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Generally speaking, Autozone and other cut-rate parts stores MAY not be the best source for technical advice....
Old Oct 8, 2004 | 06:21 PM
redbullapril23
well yea they are not the best
but they said that and someone on here told me too.
taking the alt off and taking it to the vette tech for my vette group hes doing it for free!
said that the alt fans can be either metal or plastic
mine being plastic
Old Oct 8, 2004 | 06:24 PM
96BLKTN's Avatar
96BLKTN
I used an impact socket fit fine. If it is an underdrive pully it will be larger than the stock one... Good Luck.
Old Oct 8, 2004 | 06:29 PM
redbullapril23
it uses the same bolt for the new one!
To how do i remove alt pulley?
