Ecm Help
Old Oct 8, 2004 | 12:40 PM
10-35 vette's Avatar
10-35 vette
Default Ecm Help
I HAVE AN 85 VETTE AND THE ECM IS NOT RECEIVING A PULSE FROM THE EST BUT THE EST IS GOOD HELP!!!!!!!!!!!!!!!!!!!!!?
Old Oct 8, 2004 | 01:40 PM
bogus's Avatar
bogus
You can put a scanner or meter on the EST wire, and it's good at the ECM?
Then you need a new ECM.
I would suggest searching over in Scan and Tune... you should consider upgrading to a newer ECU. The earlier ECUs are SO slow... newer ones are much faster!!! Faster means better refinement.
The older ones are so slow, that if you attach a scan tool to them, it can cause the motor to nearly die! Also, the data refresh rates are SO slow, you cannot get a good picture of what is going on.
Old Oct 8, 2004 | 03:24 PM
comp's Avatar
comp
what yr to upgrade to?
To Ecm Help
