Headlight motor run-on
Old Oct 8, 2004 | 02:01 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Headlight motor run-on
I tried to use the search feature but it did not return any usable info so here goes.
The pass. side headlight motor on my 90 keeps running for like 10 sec after the light reaches the stop either open or closed. Everything else seems to be fine it just doesn't want to stop.
Any ideas? Gears? Bushings?
Dale
Old Oct 8, 2004 | 03:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The problem is either that the headlight isn't completing it's rotation or the limit switch in the motor is defective.
Turn the manual **** atop the assembly; if it feels "mushy" replace the bushings.
Old Oct 8, 2004 | 03:37 PM
pwrful c4's Avatar
pwrful c4
Dale,Ihad the exact same problem,replaced the bushings and ended the problem.
Old Oct 8, 2004 | 04:08 PM
eptaylor's Avatar
eptaylor
There is no limit switch in the motor so replace the bushings as mentioned earlier. Fixed mine this way too.
Old Oct 8, 2004 | 05:25 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Are these the bushings that can be purchased from a hardware store that I've read of here on the forum? I think one of my lights is starting to do the same thing.
Old Oct 11, 2004 | 01:21 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yes. Although there's controversey surrounding their use, I bought my bushings from Home Depot, installed them, and my lights are working fine. Other have used them and had them fail shortly after installing them.
It's a turkey shoot. I just want you to go in eyes wide open before you commit to purchase so you or no one else here can beef I sold you a bum steer.
Or you can order the bushings from MAM, Eckler's and the other big-dog retailers for the O.E.M. Delrin bushings and pay a whole lot more.
The Home Depot item number is 595609. That's all you need to tell the clerk when you go in there. You will need six (6) of these nylon spacers in order to repair both lights.
Follow the instructions below to install.
http://www.corvetteforums.net/tech/headlight.html
Old Oct 11, 2004 | 03:42 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Cool. Sounds like the bushings are the problem. I'll get to it this weekend and report back as to the results.
Thanks All!
Dale
Old Oct 12, 2004 | 07:17 AM
onedef92's Avatar
onedef92
Thanks All!
Dale
Take your time, print out the instructions I sent you and READ them over CAREFULLY two or more times before you commit to install. Mind what you have learned save you from the Dark Side it can...
Old Oct 12, 2004 | 10:43 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Just got done last night replacing both sets of bushings in my headlights. (Anyone else stay up until 2:00am working on their car for fun?)
I had the same problem and new bushings fixed it. The Home Depot bushings are rather thin and I had to replace the first set. When I opened it back up they were squished. Someone suggested bushings from Lowe's which are thicker but must be trimmed. Here's my thread with part numbers from lowes. http://forums.corvetteforum.com/showthread.php?t=922225
Good luck and watch for all the small shims inside and outside the motor!
Old Oct 12, 2004 | 10:47 AM
onedef92's Avatar
onedef92
I think Scoob's going with the Lowe's bushings, too. Scoob how are you fixed for C4 headlights these days?
Old Oct 13, 2004 | 07:52 AM
90EXPVette's Avatar
90EXPVette
I just did my passenger side bushings with a set I got from ebay (solid bushings). I did the other side last year and now no spinning motor
I was stuck for a while trying to get the motor off of the headlight assembly, until I realized that the cotter pin had broken and there was still a piece inside, once I got that out it was smooth sailing
Old Oct 15, 2004 | 12:20 PM
merplastic91's Avatar
merplastic91
same thing happened to mine and i went with the Ecklers bushings which solved the problem
Old Oct 17, 2004 | 05:04 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
WooHoo! My light works again!
It only took maybe 2hrs from opening the hood to closing it thanks to all of the help here. For the bushings I used ones from lowes since that is all that is near me. 1/2 x .194 x 1/2 is the size. I think they change P/Ns or manufacturers regularly so the size is the best way to find them.
Everything went together a little tight but I guess they will do a better job than the dust that was in there (yes, nothing but dust/chips). I only did the broken one and have the extra parts set aside for when the other dies.
WooHoo! Thanks for the help everybody!!
Dale
Old Oct 17, 2004 | 05:08 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Forgot to add that the Roll Pin broke down the long axis and the spring clip snapped. I found replacements at Lowes a few drawers away from the bushings. Add another $1.45 to the bill.
Dale
To Headlight motor run-on
