Okay looking at it will they be numbered like this?
1,2,3,4,5,6,7,8
9,10,11,12,13,14,15,16
I can't read anything on the connector and my haynes guide has nothing on the OBDII connector.
other then the pins will it show the code in the speedo or just flash the light. Thanks
Pin configuration you show is correct... the results will show on the speedo...
It will flash "12" three times. <blink> short pause <blink> <blink> = 12. After "12" flashes 3 times the first fault code will flash 3 times and then it moves to the second fault code, if any. At the end of the fault codes it will flash "12" again to signal the end.
