Will Datamaster run on Windows 2000?
Old Oct 9, 2004 | 10:53 AM
Cherry6speed's Avatar
Cherry6speed
Default Will Datamaster run on Windows 2000?
I visited the website and it says windows 95, 98, or NT4 operating systems. I have tried datalogging using the 2000 system and it says Pcm "no sync"
Is anyone else running with 2000? I have tried everything to make this software go.
Old Oct 9, 2004 | 05:13 PM
tim87's Avatar
tim87
My Datamaster runs on Windows 2000.
Good luck
Old Oct 9, 2004 | 05:39 PM
Cherry6speed
Ok, thanks. I wanted to eliminate another possibilty.
Old Oct 10, 2004 | 04:17 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Go to my computer systems turn off everything that has to do with any outside com ports or infered systems. I know what you are going through!!!
Old Oct 11, 2004 | 08:33 PM
Cherry6speed
Ok, I'll try it Thanks!!
Old Oct 13, 2004 | 05:46 AM
REDC4CORVETTE
Let me know if it worked and let me know what cable you are using the datamaster set up works but it will take about 200.00 to make it all work,let me know.
Old Oct 13, 2004 | 06:33 AM
conv90's Avatar
conv90
I use datamaster with my 90.
I use the Craig Moates CABL1 and ALDU1 (USB).
It works at the first attempt, the only thing that do not works is the MPG instant on the dash stuck to the lower value.
CCm equipped vehicles haves the M pin in the ALDL connctor for Datalogging and for dash data too
-Beppe-
Old Oct 15, 2004 | 04:56 PM
Cherry6speed
????? You are probably right, I bought the cable from WWW.Mastach.com
Old Oct 22, 2004 | 05:31 AM
REDC4CORVETTE
I have an IBM computer with windows 2000 and you need to turn off the modem and all infered conections,go into my computer and systems
device mgr and disable all the above ,On your computer tts program turn off your hand shake an it should work.
I bought my cable from TTS with a white thing that allows the computer to talk with the car.
Old Oct 22, 2004 | 04:13 PM
scorp508's Avatar
scorp508
2000 and XP are harder to get the scanners working if you don't have everything 105% correct if the software wasn't written specifically with them in mind. The Kernal controls 100% of what goes in and out of ports and does not allow direct access like the 9X kernal did.
Old Oct 22, 2004 | 04:34 PM
krivera's Avatar
krivera
yep!
Old Oct 27, 2004 | 10:17 AM
Cherry6speed
Ok, thanks, I will try that. Maybe I can get off this darn learning curve.
Old Oct 28, 2004 | 01:37 AM
comp's Avatar
comp
me to learning on friends
To Will Datamaster run on Windows 2000?
