Tire Question
Old Oct 10, 2004 | 10:40 AM
Kens86's Avatar
Kens86
Default Tire Question
I have had a set of BF Goodrich Comp TA's on my 86 that were installed in 1995. They have been regurlarly balanced and have been rotated (F to R). They currently have 15k miles on them. Lately, I've noticed the car tends to wander on certian road surfaces that were not an issue in the past. Do tires have a "useful life" that require I replace these even though the thread is still good?
Old Oct 10, 2004 | 10:59 AM
Ghostpilot's Avatar
Ghostpilot
When was the last allignment???
Old Oct 10, 2004 | 11:22 AM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
or normal tracking thats normal with wide tires.
Old Oct 10, 2004 | 12:51 PM
Kens86's Avatar
Kens86
Its been 2 years since it was aligned, but I've only put 2500 miles on the car since it was done. The aligment was set to zero across the board as outlined in a Corvette Fever article I read few years back. When I first drove the car after this was done , it tracked perfectly with no wander or sensitivity to the crown in the road. Now I get this floating feeling from the steering wheel. Do you think just sitting for that period of time with minimal road time require that another aligment needs to be done?
One other item done this Spring was I replaced the power steering fluid with fresh synthetic (turkey baster method). I did this because I would get a small power steering leak from the left side of the rack in cold weather (40-50 degrees FLA cold). Never had the morning sickness. No leaks since the fluid replacment, but did using the synthetic change how the rack responds?
Thanks for the help!
Old Oct 10, 2004 | 10:10 PM
rws.1's Avatar
rws.1
Tire manufactuers are now talking about 4-5 year life for tires regardless of tread wear. After that the rubber compund tends to go hard and loses traction. Even though no weather craking is visible, the tires can loose their grip. this phenomenon may be teh cause of your wandering.
Old Oct 10, 2004 | 10:12 PM
mean8t's Avatar
mean8t
They might be bad seven years is all that a tire is typically good for (general rule of thumb not definatively). Are the tires cracking? If not then you probably are all right but just watch them cloesly.
Old Oct 10, 2004 | 11:50 PM
black85vette's Avatar
black85vette
5 years dude! have you seen what a blown tire can do to a fender? tire $$$ body repairs PAINT $$$$'s peace of mind PRICELESS !!!!!
Old Oct 11, 2004 | 12:43 AM
comp's Avatar
comp
I've read this a few different place's, some may be to sell more tire's But i think most is true
Old Oct 11, 2004 | 03:46 PM
Old182A's Avatar
Old182A
Just put a set of Kumho Ecsta MX's on my '91 Vert (based on consensus from a thread on this Forum), and now the car darts a little (it tracked perfectly with the Potenzas). FWIW: My experience has been that wandering or darting is typically caused by toe-out. It's going into the front-end shop soon for an alignment.
Old Oct 11, 2004 | 03:50 PM
mikey whipreck's Avatar
mikey whipreck
hmm.... I guess this means the tires that were put on Our oldsmobile in the 1960's, are probably near the end of their life span?
To Tire Question
