L-98 Mod Questions.....
I myself enjoy taking an efficient, underpowered car and out running some fire breathing over powered monster in the 1/4. I do know he will eventully catch me but quite often it is after the finish line. Race on!
High 12's are very possible with a L98 and bolton mods. But you have to be able to 60' hard. That is the key with an L98.
Vic
i can't wait for the -1500 DA like we had late october last year
Wait till we see a -500 DA day.
Vic
u ran a 13.34 at 102MPH with some mods. gee golly, i run a mph close to that and i dont even break into the 13's......
[/QUOTE]hey man drop tire pressure and don't be afraid to heat the **** out of them! i dropped tire pressure to 18 psi on my 285/40/17" F1's and pulled several 1.81 60' times on a stock 1600 stall and 2.59 gears!
manuals won't 60' that good but 1.9x's are very doable and that would put you mid 13's
Thanks man got'em!
James
i'm looking at your pics and just curious how come you didn't siamese the upper plenum and runners? and also in your honest opinion was it worth it? i was looking at your website and noticed you didn't make any more power either torque or hp on the dyno before and after in the same weather conditions.
i'm just debating on doing this because of the 2.59 gearing and stock 1600 stall. right now there is a dead spot from launch till about 2400 rpm or so before the car pulls like a ****. always been like that but getting shorter with more mods i add. just trying to max out the stock setup before i do H/C/I setup on the new motor.
I believe I lost a little low end torque (as expected) but moving up from a 1,500rpm to a 2,000rpm TC more than compensated for any such loss.
So if your engine doesn't come on till low to mid 2k RPM you might try say a 2,400rpm TC. Then if you do the siamese intake base you will not feel any loss on low end and she will pull strongly well into the 5k RPM range.
BTW, Vic's '89 has one strong Vette; indeed in the last round on Sat. he made a 12.755sec pass (on the brakes) on a 12.68sec dial against my 13.455sec pass on a 13.42 dial.
Vic is pulling 1.7xx sec short times on ET Streets with 3.07 gears while I'm pulling 1.9xx sec short times on GY Eagles (Gatorbacks) with 2.59 gears. So indeed gears do help but traction is paramount.
still debating on how far i want to go on the TPI system before i do the other mods. just really trying to see how far i can take it on stock internals, stock 1600 stall, stock 2.59 rear gears.James how i was 60'ing with mine was 18.5 psi with a nice burnout and launching at 1300 rpm. i tried several different ways, leaving off dead idle, different stall speeds, but 1300 rpm seemed to net the best 60' time.
might redyno the car next week after i put some brakes on the car. man i wish you guys were closer to Cecil County! i might have to try and make it to E-Town for a race to meet you guys! been saying that all year
I appreciate that it is a long drive; it takes me 1.5hrs and those morning events are tough to make sometimes.
i'll check the schedule and see what i can do
Greg Parker
