C4 Grease/Zerk Fitting Count?
Old Oct 11, 2004 | 09:33 AM
DukeDiablo's Avatar
DukeDiablo
Default C4 Grease/Zerk Fitting Count?
Dear Forum-
Just wanted to get a quick count of all the zerk fittings I should look for on my 96 before I crawl under with the gun.
Thanks in advance.
Old Oct 11, 2004 | 03:22 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I believe that there are only 4... one at each of the ball joints on the front suspension.
Old Oct 11, 2004 | 05:35 PM
Strick's Avatar
Strick
Don't forget your tie rods.
Old Oct 11, 2004 | 07:34 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Also take a look at your universal joints! They are lubricatable on my 88
seeya
Jack
Old Oct 11, 2004 | 07:51 PM
scorp508's Avatar
scorp508
I believe some of the later C4s have non-greaseable tie rods. If you order a replacement from GM these days you get a non-greaseable one.
Old Oct 11, 2004 | 08:35 PM
Kanmer's Avatar
Kanmer
Default Rear Also
I was suprised to find 2 on the rear of my 86 in the hub area of each wheel
BOb
Old Oct 11, 2004 | 09:36 PM
DukeDiablo's Avatar
DukeDiablo
Thanks for all the replies.
I'm just so used to my old Scout where nearly everything had a grease fitting..and now with newer cars, it seem everything is sealed.
Thanks again.
To C4 Grease/Zerk Fitting Count?
