Which Intake Gasket???
1 Post
I'm getting ready to start putting my new engine together. I purchased Fel-Pro 1204's. I noticed the rear coolant passages are not blocked. The stock Gaskets have the rear coolant passages blocked. which type should I use? '89 L98.
Thanks!
Ron
Thanks!
Ron
I'd stick to the stock gaskets to make sure you get the right ones. FYI - the manual is wrong as it wants you to put the blocked passages in the front. I put mine on the way the old ones came off towards the back.
The high performance head gaskets I bought from GMPP for my 89L98 are made by Felpro
1 Post
Yep, that's what I figured. Any other thoughts anyone??? My head Gaskets are Fel-Pro... they look Bulletproof. the Intake Gaskets are very nice also. I'd really like to use them. Will I have any problems with the rear passages open???
The factory gaskets last only about 1 1/2 yrs and start leaking coolant. When the warranty ran out, I paid extra for the Fel-Pro teflon coated gaskets and haven't replaced them since. I highly recommend them.
Use the proper gaskets with the rear passages blocked. A knucklehead installed the wrong ones last year on me, and I didn't find out until I tore into the motor to remove the heads. I at first thought it was my imagination that the car ran hotter last year, ( even with a 160 stat, and 180 deg dual fan switch) The stock GM intake gasket is very good for a stock base, and Felpro makes the correct one also. Make sure that both components are sparkling clean (no scotch brite!) and use some RTV around the rear coolant passage.
[This message has been edited by h rocks (edited 08-01-2001).]
