TPS Questions
1. If TPS is out of adjustment TC Lockup could be a problem at part throttle right?
On the highway at 70 when I accelerate it acts like it's gear hunting but the RPM doesn't shift enough for it to be 3rd
2. Could a bad TPS signal affect the IAC? Friggin idle and Tip-In just KEEP GETTING WORSE!!
Thanks for all the help
If problems at all throttle postitions verify the TPS connection is solid and check the TB shaft for escessive wear.
