ATF mixing
Old Jul 31, 2001 | 05:33 AM
GlockLT4's Avatar
GlockLT4
Is it OK to mix Mobil 1 synthetic ATF with just your standard every day ATF? I am going to change out the fluid and filter and need to know if it is ok to replace what I take out with Mobil 1 ATF.
Old Jul 31, 2001 | 09:09 AM
Flame Red's Avatar
Flame Red
Yes it is ok to mix Mobil-1 with regular, but there is a better way to replace the fluid. Remove the upper trans cooler pipe that goes into the radiator. Attach a hose to it and place the other end into a bucket. Get about 12 quarts of Mobil-1 and with a friend start the car and add fresh fluid as the old fluid comes out. This fluid exchange will get more of the old stuff out over just dropping the pan.
I must admit it is fairly messy, but so is dropping the pan.
Flame Red
Old Jul 31, 2001 | 03:22 PM
GlockLT4's Avatar
GlockLT4
Originally Posted by Flame Red
94,
Flame Red
[/color]
Yes, I know I can flush through the radiator hose. I had Firestone do that for me about 3 months ago, so the fulid is fairly fresh. The main thing I want to do is drop the pan and change the filter (since it hasn't been done) and clean off the magnet and anything else that I can on the underside of the valvebody. Also, because of the high temps around here, I want to get some synthetic fluid in there to help keep it from bubbling up a little like it is now (which is a sign of too much heat)
[This message has been edited by Glock'94 (edited 07-31-2001).]
To ATF mixing
