how much hp for a sum what stock 383
CI 7-8-9-10 Veteran
St. Jude Donor '08
i was wandering what a sum what stock 383 would put out (hP) this would be a motor out of an 85 vette 230 stock!! on this motor would be stock fuel inj,48 mm tb,no pressure reg ,etc basicaly jus a new crank,summit rebuild kit,comp cam kit 477-480 I was wandering what this would put out for now ?? thanks JAY
since all power is made at low rpms as stock, you may gain a little more torque but you would be lucky if horsepower breaks even the same as now.
You need to plan a few more tricks to go with the added cubes or your simply wasting money.
