The general told me my injectors were leaking so I took it to the Corvette dealer I bought it from and they replaced them. Now I learn that the injectors they put in are not OEM and have a higher output then necessary for an 85 so they had to put an adjustable fuel pressure regulator on. It ran great a few days now is back to where it started. I had a scanner put on it and I'm told the pulse width is not consistant and ranges for 5 to 20. This may be impacting on the idle as well as the mileage. What do I do?? I can't afford new injectors again and the dealer said he can't return the one (the wrong ones!) he put in!! Can this be rectified? I also need to put in an ignition module and I've had a variety of prices. Pep Boys $34, local parts store said an 85 has two different modules and they need my VIN. AutoZone said $14!! and of course the general said $70. What is the difference between all of these?? I'm very anxious to solve the injector issue. Can the larger output ones be used? Thanks for whatever help you can offer.
I would be interested in where the dealer got the injectors from. You need a set of either 21#or 22# injectors. Any larger than that and you will have to turn the pressure down on them which give a very bad spray pattern. As far as the module, call JEG's and get and Accel module for your car. The same module goes from 81-91. The reason the dealer needs your vin is because of a part# change when the changed vendors. You would get the same module either way. If you need injectors I have a set of new 21# Accel's I will sell for $300. Just e-mail me if you are interested. However I would make whoever put the wrong injectors in it refund your money.
Sorry I hate to tell you this, but all TPI 350's including the Corvette came with 22# injectors. I used to think the same that they came with 24's, but they didn't. I have had two 85's one of them was only 2 years old when we bought it and they both had 22's. Sorry but at least you know now.
Sorry I hate to tell you this, but all TPI 350's including the Corvette came with 22# injectors. I used to think the same that they came with 24's, but they didn't. I have had two 85's one of them was only 2 years old when we bought it and they both had 22's. Sorry but at least you know now.[/B][/color]
Learn something new everyday [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
The difference in the ignition modules: the auto part stores fail to realize that all 85 Corvettes have a 7 pin module. The 2 modules they want to sell you are a 4 or a 7 pin. You need the 7 pin. The 4 pin was HEI but non-computer controlled with vacuum and mechanical advance. The computer in your Vette controls the advance and thus, has 3 more pins on it. -Matt-
if your injector pulse width is that bad, id look to see if i could find someone with an 85 ecm that you could swap in and test. it sounds like your ecm may be bad, since the problem went away and came back. i had an ecm that would do that. it would run fine on some days, and others it would run like pure sh*t with horrible gas milage. all fixed after i put in a new ecm. and yes, the 85 had 22lb injectors. thats a bunch of bs that the dealer sold you stuff you didnt need. id be calling the B.B.B. on their a*s.
